How to use storage tags
This page explains how to use MAAS storage tags. In order to create or modify block device tags, the device has to be in an “available” state, with no active partitions.
Create block device tags (UI)
To create and assign tags to block devices, select Machines > machine > Storage > Available disks and partitions > Edit…. Add Tags as desired, and Save.
Delete block device tags (UI)
To create and assign tags to block devices, select Machines > machine > Storage > Available disks and partitions > Edit…. Remove tags by selecting the X on the tag name, and Save your changes.
List storage tags (UI)
To see block device and partition tags in the UI, you can list all storage links by using the filter tool on the machine list. Select Machines > Filters > Storage tags. Select tag(s) to filter against; the screen will immediately narrow to match your selections. Uncheck tags to return to the previous view.
View block device tags (UI)
To view all tags associated with block devices on a given machine, select Machines > machine > Storage > Available disks and partitions.
View partition tags (UI)
To view all tags associated with partitions on a given machine, select Machines > machine > Storage > Available disks and partitions.
Find block device ID (CLI)
| @tsv' | column -t
For example:
| @tsv' | column -t
system_id  block_device_id  path                    avail_size
qk4b3g     10               /dev/disk/by-dname/sda  0
The path component is printed to help you confirm that you are choosing the right block device when there are several present. The avail-size column will tell you whether you can operate on that block device at all. If the available size is “0,” for example, you can’t set a block device tag on any part of that drive. Instead, you’d want to see something like this:
xn8taa     8                /dev/disk/by-dname/sda  1996488704
Assign block device tags (CLI)
For example:
If this command succeeds, it will display Success, followed by a JSON sequence describing the new state of the block device.
Not Found
Remove block device tags (CLI)
For example:
Note that if you try to remove a tag from a block device that is not available, that is, from a block device that is in use, you will get a result like this:
Not Found
On the other hand, if you try to remove a tag that is not assigned to the block device you’ve chosen, MAAS will simply return Success, followed by a JSON sequence describing the current state of the block device.
List tags for all block devices (CLI)
For example:
id  tags
8   hello  ssd  trinkoplinko
View tags for one block device (CLI)
For example:
id  tags
9   20gig  ssd
10  250Gs  ssd
Find partition ID (CLI)
|@tsv' | column -t
For example:
|@tsv' | column -t
system_id  block_dev_id  part_id  path
xn8taa     8             67       /dev/disk/by-dname/sda-part1
The path component is printed to help you confirm that you are choosing the right partition, when there are several present.
Assign partition tags (CLI)
For example:
If this command succeeds, it will display Success, followed by a JSON sequence describing the new state of the partition.
Not Found
Remove partition tags (CLI)
For example:
Note that if you try to remove a tag from a partition that is not available, that is, from a partition that is in use, you will get a result like this:
Not Found
On the other hand, if you try to remove a tag that is not assigned to the partition you’ve chosen, MAAS will simply return Success, followed by a JSON sequence describing the current state of the partition.
List tags for all partitions (CLI)
| @tsv' | column -t
For example:
| @tsv' | column -t
id  tags
54  farquar swap opendisk
67  foobar  farquar
97  foobar
View tags for one partition (CLI)
To view tags for one partition, enter
For example:
id  tags
67  farquar foobar
