How to set up PostgreSQL HA hot standby (snap/2.9/CLI)
  1. PRIMARY_PG_IP: The IP address of the host that contains the primary database.
  2. SECONDARY_PG_IP: The IP address of the host that contains the secondary database.
  3. REP_USER: The internal database user that manages replication on the primary.
  4. REP_USER_PW: The password of the replication user.
  5. REP_ARCHIVE: The directory where the database will place files to be replicated.
Primary
Create internal database user
sudo mkdir -p $REP_ARCHIVE
Configure for replication
listen_addresses = '*'
wal_level = hot_standby
archive_mode = on
max_wal_senders = 3
Restart the database
Secondary
  1. CPU architecture
  2. OS type and version
  3. PostgreSQL version
sudo apt install postgresql
Password:
hot_standby = on
Configure for recovery
standby_mode = on
Start the database
Start the database:
Verification of replication
(5 rows)
