There are two conditions that may cause Vault-protected secrets to become unavailable: when the Vault is sealed (using vault operator seal
– see the Vault documentation↗
and when the Vault is unreachable through misconfiguration or other failure.
When the Vault is sealed, all queries involving secrets will fail with a user error mentioning that the Vault has been sealed. Unsealing the Vault requires operator intervention, via the vault operator unseal
command (again, see the Vault documentation↗
. MAAS will indicate when this is needed.
Vault may become unreachable due to a network failure, due to incorrect configuration of a region controller, or other unintentional situations. When the Vault is unreachable, MAAS will inform the users that interactions with Vault will fail.
MAAS will make every attempt to present a meaningful error if Vault is not functional. This includes related authentication errors when attempting to login to MAAS.
Hashicorp Vault↗
is integrated with MAAS version 3.3. To enable Vault for use with your MAAS, please upgrade to MAAS 3.3.
