Network testing (snap/2.7/UI)
Four questions you may have:
  1. How do I use network link testing?
  2. How can I detect slow network links?
  3. How do I use network validation and testing scripts?
  4. How can I customise network testing?
Network validation and testing scripts
MAAS can check this link and recognise that there’s no connectivity, which alleviates hard-to-detect network issues:
Customise network testing
