About storage
About UEFI booting
Every layout type supports a machine booting with UEFI. In such a case, MAAS automatically creates an EFI boot partition (/boot/efi
). Other than setting the machine to boot from UEFI, the user does not need to take any additional action.
The EFI partition, if created, will be the first partition (sda1
) and will have a FAT32 filesystem with a size of 512 MB.
About disk erasure
About disk erasure types
- Standard erasure
- Secure erasure
- Quick erasure
Abot standard erasure
About secure eraseure
About quick erasure
- Use ‘secure erase’ if the disk supports it
- If it does not then use ‘quick erase’
About block devices
Physical
Virtual
About partitions
About storage restrictions
- An EFI partition is required to be on the boot disk for UEFI.
- You cannot place partitions on logical volumes.
- You cannot use a logical volume as a Bcache backing device.
About VMFS datastores
MAAS can configure custom local VMware VMFS Datastore layouts to maximise the usage of your local disks when deploying VMware ESXi. As VMware ESXi requires specific partitions for operating system usage, you must first apply the VMFS6 storage layout. This layout creates a VMFS Datastore named datastore1
which uses the disk space left over on the boot disk after MAAS creates the operating system partitions.
How to list block devices
Output:
"id": 10,
"serial": "",
"block_size": 4096,
"available_size": 0,
"filesystem": null,
"id_path": "/dev/vda",
"size": 5368709120,
"model": "",
"type": "physical",
"uuid": null,
"used_size": 5365563392,
"partitions": [
"bootable": false,
"id": 9,
"size": 5360320512,
"type": "partition",
"filesystem": {
"mount_options": null,
"label": null,
"fstype": "lvm-pv",
"mount_point": null
"tags": [
"rotary"
"name": "vda"
"id": 11,
"serial": null,
"block_size": 4096,
"filesystem": {
"label": "root",
"fstype": "ext4",
"mount_point": "/"
"id_path": null,
"size": 3221225472,
"partition_table_type": null,
"model": null,
"type": "virtual",
"used_size": 3221225472,
"partitions": [],
"tags": [],
"name": "vgroot-lvroot"
How to read a block device
"name": "vgroot-lvroot",
"type": "virtual",
"filesystem": {
"mount_point": "/",
"fstype": "ext4",
"label": "root"
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
How to create a block device
"name": "vdb",
"used_for": "Unused",
"type": "physical",
"used_size": 0,
"filesystem": null,
"id_path": "",
"id": 12,
"block_size": 4096,
"tags": [],
"uuid": null,
"serial": "QM00001",
"partitions": [],
"size": 21474836480,
"model": "QEMU"
How to update a block device
"block_size": 4096,
"filesystem": null,
"model": "QEMU",
"name": "newroot",
"partitions": [],
"tags": [],
"used_size": 0,
"id_path": "",
"uuid": null,
"id": 12,
"type": "physical",
"serial": "QM00001"
How to delete a block device
Format Block Device
"block_size": 4096,
"size": 3221225472,
"filesystem": {
"label": "",
"fstype": "ext4",
"mount_point": null
"model": null,
"partitions": [],
"tags": [],
"id_path": null,
"id": 11,
"type": "virtual",
"serial": null
"available_size": 3221225472,
"type": "virtual",
"used_size": 0,
"filesystem": null,
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
How to mount a block device
"type": "virtual",
"filesystem": {
"mount_point": "/srv",
"mount_options": "",
"fstype": "ext4",
"label": ""
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
How to unmount a block device
"type": "virtual",
"filesystem": {
"mount_point": null,
"fstype": "ext4",
"label": ""
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
How to list partitions
"bootable": false,
"id": 9,
"resource_uri":
"size": 5360320512,
"filesystem": {
"label": null,
"fstype": "lvm-pv",
"mount_point": null
How to create a partition
"bootable": false,
"filesystem": null,
"id": 10,
"size": 5360320512,
How to delete a partition
How to format a partition
"id": 9,
"size": 5360320512,
"bootable": false,
"filesystem": {
"fstype": "ext4",
"label": ""
How to unformat a partition
"bootable": false,
"filesystem": null,
"id": 10,
"size": 5360320512,
How to mount a partition
"bootable": false,
"id": 10,
"size": 5360320512,
"filesystem": {
"label": "",
"fstype": "ext4",
How to unmount a partition
"bootable": false,
"id": 10,
"size": 5360320512,
"filesystem": {
"label": "",
"fstype": "ext4",
"mount_point": null
"id": 3,
"size": 2000003072
How to list VMFS datastores
"human_size": "45.8 GB",
"filesystem": {
"fstype": "vmfs6",
"name": "datastore1",
"system_id": "4qxaga",
"devices": [
"size": 35026632704,
"bootable": false,
"tags": [],
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 5,
"id": 71,
"size": 10729029632,
"bootable": false,
"tags": [],
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 6,
"id": 77,
"id": 17,
"size": 45755662336,
How to view a VMFS datastore
"system_id": "b66fn6",
"id": 18,
"filesystem": {
"fstype": "vmfs6",
"human_size": "2.8 GB",
"devices": [
"size": 2814377984,
"bootable": false,
"tags": [],
"id": 80,
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 1,
"size": 2814377984,
"devices": [
"size": 2814377984,
"bootable": false,
"tags": [],
"device_id": 1,
"filesystem": {
"fstype": "vmfs6",
"label": null,
"id": 80,
"name": "datastore42",
"filesystem": {
"fstype": "vmfs6",
"id": 19,
"size": 2814377984,
How to edit a VMFS datastore
"id": 19,
"filesystem": {
"fstype": "vmfs6",
"human_size": "13.5 GB",
"devices": [
"size": 2814377984,
"bootable": false,
"tags": [],
"id": 80,
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 1,
"bootable": false,
"tags": [],
"id": 86,
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 2,
"size": 13543407616,
Storage layouts reference
There are three layout types:
- Flat layout
- LVM layout
- bcache layout
The layout descriptions below will include the EFI partition. If your system is not using UEFI, regard sda2
as sda1
(with an additional 512 MB available to it).
Flat layout storage reference
With the Flat layout, a partition spans the entire boot disk. The partition is formatted with the ext4 filesystem and uses the /
mount point:
Name | Size | Type | Filesystem | Mount point |
sda | - | disk | ||
sda1 | 512 MB | part | FAT32 | /boot/efi |
sda2 | rest of sda | part | ext4 | / |
boot_size
: Size of the boot partition on the boot disk. Default is 0, meaning not to create the boot partition. The ‘/boot’ will be placed on the root filesystem. -
root_device
: The block device on which to place the root partition. The default is the boot disk. -
root_size
: Size of the root partition. Default is 100%, meaning the entire size of the root device.
LVM storage layout reference
The LVM layout creates the volume group vgroot
on a partition that spans the entire boot disk. A logical volume lvroot
is created for the full size of the volume group; is formatted with the ext4 filesystem; and uses the /
mount point:
sda | - | disk | ||
sda2 | rest of sda | part | lvm-pv(vgroot) | |
lvroot | rest of sda | lvm | ext4 | / |
vgroot | rest of sda | lvm |
boot_size
root_device
root_size
: Size of the root partition. Default is 100%, meaning the entire size of the root device. -
vg_name
: Name of the created volume group. Default isvgroot
lv_name
: Name of the created logical volume. Default islvroot
lv_size
: Size of the created logical volume. Default is 100%, meaning the entire size of the volume group.
A bcache layout will create a partition that spans the entire boot disk as the backing device. It uses the smallest block device tagged with ‘ssd’ as the cache device. The bcache device is formatted with the ext4 filesystem and uses the /
mount point. If there are no ‘ssd’ tagged block devices on the machine, then the bcache device will not be created, and the Flat layout will be used instead:
sda | - | disk | ||
sda2 | rest of sda | part | bc-backing | |
sdb (ssd) | - | disk | ||
sdb1 | 100% of sdb | part | bc-cache | |
bcache0 | per sda2 | disk | ext4 | / |
boot_size
root_device
: The block device upon which to place the root partition. The default is the boot disk. -
root_size
cache_device
: The block device to use as the cache device. Default is the smallest block device tagged ssd. -
cache_mode
: The cache mode to which MAAS should set the created bcache device. The default iswritethrough
cache_size
: The size of the partition on the cache device. Default is 100%, meaning the entire size of the cache device. -
cache_no_part
: Whether or not to create a partition on the cache device. Default is false, meaning to create a partition using the givencache_size
. If set to true, no partition will be created, and the raw cache device will be used as the cache.
Name | Size | Type | Use |
sda | - | disk | |
sda1 | 3 MB | part | EFI |
sda2 | 4 GB | part | Basic Data |
sda3 | Remaining | part | VMFS Datastore 1 |
sda4 | - | skipped | |
sda5 | 249 MB | part | Basic Data |
sda6 | 249 MB | part | Basic Data |
sda7 | 109 MB | part | VMware Diagnostic |
sda8 | 285 MB | part | Basic Data |
sda9 | 2.5 GB | part | VMware Diagnostic |
root_device
: The block device upon which to place the root partition. Default is the boot disk. -
root_size
: Size of the default VMFS Datastore. Default is 100%, meaning the remaining size of the root disk.
