About storage
About UEFI booting
About disk erasure
About disk erasure types
- Standard erasure
- Secure erasure
- Quick erasure
Abot standard erasure
About secure eraseure
About quick erasure
- Use ‘secure erase’ if the disk supports it
- If it does not then use ‘quick erase’
About block devices
Physical
Virtual
About partitions
About storage restrictions
- An EFI partition is required to be on the boot disk for UEFI.
- You cannot place partitions on logical volumes.
- You cannot use a logical volume as a Bcache backing device.
About VMFS datastores
How to erase disks
and not:
How to list block devices
Output:
"id": 10,
"serial": "",
"block_size": 4096,
"available_size": 0,
"filesystem": null,
"id_path": "/dev/vda",
"size": 5368709120,
"model": "",
"type": "physical",
"uuid": null,
"used_size": 5365563392,
"partitions": [
"bootable": false,
"id": 9,
"size": 5360320512,
"type": "partition",
"filesystem": {
"mount_options": null,
"label": null,
"fstype": "lvm-pv",
"mount_point": null
"tags": [
"rotary"
"name": "vda"
"id": 11,
"serial": null,
"block_size": 4096,
"filesystem": {
"label": "root",
"fstype": "ext4",
"mount_point": "/"
"id_path": null,
"size": 3221225472,
"partition_table_type": null,
"model": null,
"type": "virtual",
"used_size": 3221225472,
"partitions": [],
"tags": [],
"name": "vgroot-lvroot"
How to read a block device
"name": "vgroot-lvroot",
"type": "virtual",
"filesystem": {
"mount_point": "/",
"fstype": "ext4",
"label": "root"
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
How to create a block device
"name": "vdb",
"used_for": "Unused",
"type": "physical",
"used_size": 0,
"filesystem": null,
"id_path": "",
"id": 12,
"block_size": 4096,
"tags": [],
"uuid": null,
"serial": "QM00001",
"partitions": [],
"size": 21474836480,
"model": "QEMU"
How to update a block device
"block_size": 4096,
"filesystem": null,
"model": "QEMU",
"name": "newroot",
"partitions": [],
"tags": [],
"used_size": 0,
"id_path": "",
"uuid": null,
"id": 12,
"type": "physical",
"serial": "QM00001"
How to delete a block device
Format Block Device
"block_size": 4096,
"size": 3221225472,
"filesystem": {
"label": "",
"fstype": "ext4",
"mount_point": null
"model": null,
"partitions": [],
"tags": [],
"id_path": null,
"id": 11,
"type": "virtual",
"serial": null
"available_size": 3221225472,
"type": "virtual",
"used_size": 0,
"filesystem": null,
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
How to mount a block device
"type": "virtual",
"filesystem": {
"mount_point": "/srv",
"mount_options": "",
"fstype": "ext4",
"label": ""
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
How to unmount a block device
"type": "virtual",
"filesystem": {
"mount_point": null,
"fstype": "ext4",
"label": ""
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
How to list partitions
"bootable": false,
"id": 9,
"resource_uri":
"size": 5360320512,
"filesystem": {
"label": null,
"fstype": "lvm-pv",
"mount_point": null
How to create a partition
"bootable": false,
"filesystem": null,
"id": 10,
"size": 5360320512,
How to delete a partition
How to format a partition
"id": 9,
"size": 5360320512,
"bootable": false,
"filesystem": {
"fstype": "ext4",
"label": ""
How to unformat a partition
"bootable": false,
"filesystem": null,
"id": 10,
"size": 5360320512,
How to mount a partition
"bootable": false,
"id": 10,
"size": 5360320512,
"filesystem": {
"label": "",
"fstype": "ext4",
How to unmount a partition
"bootable": false,
"id": 10,
"size": 5360320512,
"filesystem": {
"label": "",
"fstype": "ext4",
"mount_point": null
"id": 3,
"size": 2000003072
How to list VMFS datastores
"human_size": "45.8 GB",
"filesystem": {
"fstype": "vmfs6",
"name": "datastore1",
"system_id": "4qxaga",
"devices": [
"size": 35026632704,
"bootable": false,
"tags": [],
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 5,
"id": 71,
"size": 10729029632,
"bootable": false,
"tags": [],
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 6,
"id": 77,
"id": 17,
"size": 45755662336,
How to view a VMFS datastore
"system_id": "b66fn6",
"id": 18,
"filesystem": {
"fstype": "vmfs6",
"human_size": "2.8 GB",
"devices": [
"size": 2814377984,
"bootable": false,
"tags": [],
"id": 80,
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 1,
"size": 2814377984,
"devices": [
"size": 2814377984,
"bootable": false,
"tags": [],
"device_id": 1,
"filesystem": {
"fstype": "vmfs6",
"label": null,
"id": 80,
"name": "datastore42",
"filesystem": {
"fstype": "vmfs6",
"id": 19,
"size": 2814377984,
How to edit a VMFS datastore
"id": 19,
"filesystem": {
"fstype": "vmfs6",
"human_size": "13.5 GB",
"devices": [
"size": 2814377984,
"bootable": false,
"tags": [],
"id": 80,
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 1,
"bootable": false,
"tags": [],
"id": 86,
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 2,
"size": 13543407616,
Storage layouts reference
There are three layout types:
- Flat layout
- LVM layout
- bcache layout
Flat layout storage reference
| Name | Size | Type | Filesystem | Mount point |
| sda | - | disk | ||
| sda1 | 512 MB | part | FAT32 | /boot/efi |
| sda2 | rest of sda | part | ext4 | / |
boot_size: Size of the boot partition on the boot disk. Default is 0, meaning not to create the boot partition. The ‘/boot’ will be placed on the root filesystem. -
root_device: The block device on which to place the root partition. The default is the boot disk. -
root_size: Size of the root partition. Default is 100%, meaning the entire size of the root device.
LVM storage layout reference
| sda | - | disk | ||
| sda2 | rest of sda | part | lvm-pv(vgroot) | |
| lvroot | rest of sda | lvm | ext4 | / |
| vgroot | rest of sda | lvm |
root_size: Size of the root partition. Default is 100%, meaning the entire size of the root device. -
vg_name: Name of the created volume group. Default isvgroot. -
lv_name: Name of the created logical volume. Default islvroot. -
lv_size: Size of the created logical volume. Default is 100%, meaning the entire size of the volume group.
| sda | - | disk | ||
| sda2 | rest of sda | part | bc-backing | |
| sdb (ssd) | - | disk | ||
| sdb1 | 100% of sdb | part | bc-cache | |
| bcache0 | per sda2 | disk | ext4 | / |
root_device: The block device upon which to place the root partition. The default is the boot disk. -
cache_device: The block device to use as the cache device. Default is the smallest block device tagged ssd. -
cache_mode: The cache mode to which MAAS should set the created bcache device. The default iswritethrough. -
cache_size: The size of the partition on the cache device. Default is 100%, meaning the entire size of the cache device. -
cache_no_part: Whether or not to create a partition on the cache device. Default is false, meaning to create a partition using the givencache_size. If set to true, no partition will be created, and the raw cache device will be used as the cache.
| Name | Size | Type | Use |
| sda | - | disk | |
| sda1 | 3 MB | part | EFI |
| sda2 | 4 GB | part | Basic Data |
| sda3 | Remaining | part | VMFS Datastore 1 |
| sda4 | - | skipped | |
| sda5 | 249 MB | part | Basic Data |
| sda6 | 249 MB | part | Basic Data |
| sda7 | 109 MB | part | VMware Diagnostic |
| sda8 | 285 MB | part | Basic Data |
| sda9 | 2.5 GB | part | VMware Diagnostic |
root_device: The block device upon which to place the root partition. Default is the boot disk. -
root_size: Size of the default VMFS Datastore. Default is 100%, meaning the remaining size of the root disk.
