This page offers actionable steps for securing your MAAS instance.
Firewalls
For a secure MAAS setup, you need to regulate the network ports accessible on your rack controllers. Below is a table outlining the essential TCP ports for MAAS communication:
Port(s) | Description |
5240 |
HTTP traffic with each region controller. In HA environments, port 80 is commonly used. |
5241 - 5247 |
Allocated for MAAS internal services. |
5248 |
Designated for rack HTTP communication. |
5250 - 5270 |
Reserved for region workers (RPC). |
To further harden your security, consider configuring your firewall^ to allow only the ports MAAS uses. For example, if you’re using ufw
, the commands would look like:
sudo ufw enable
sudo ufw allow 5240
sudo ufw allow 5248
sudo ufw allow 5241:5247/tcp
sudo ufw allow 5241:5247/udp
sudo ufw allow 5250:5270/tcp
sudo ufw allow 5250:5270/udp
Note that the above commands are illustrative; your specific setup and MAAS version may require different settings. Always refer to the relevant firewall documentation for your system.
Pro tip: This example assumes you’re using
ufw
for your firewall settings. Always consult your system-specific firewall manual for the most accurate instructions.
TLS termination
Enhancing both security and availability of your MAAS deployment can be achieved by using a TLS-terminating load balancer. For this purpose, we recommend HAProxy^. This guide outlines how to establish one.
Sidebar: Understanding TLS-terminated load balancing
Within MAAS, a load balancer routes incoming Web UI and API requests across several region controllers. This lessens MAAS workload and reduces user request latency. This is usually part of a high-availability (HA) setup, but MAAS also supports other HA configurations for BMC access and DHCP.
A TLS-terminated load balancer carries out encryption and decryption as close to the edge of the network as possible, in this case, right at the load balancer. While “SSL” is an outdated term, we opt for “TLS,” or Transport Layer Security. TLS aims to ensure both privacy and data integrity between multiple applications, achieved through symmetric cryptography and message authentication codes.
PEM files
Firstly, amalgamate your SSL certificate (mysite.com.crt
) and key pair (mysite.com.key
) into a single PEM file:
Depending on your certificate authority, you may also need to include your root and intermediate CA certificates in the same PEM file.
HAProxy
To deploy HAProxy, run the following:
sudo apt-get update
sudo apt-get install haproxy
Then, modify /etc/haproxy/haproxy.cfg
. In the global
section, set the maximum number of concurrent connections:
Additionally, include the following line to configure temporary DHE key sizes:
In the defaults
section under mode http
, add:
option forwardfor
option http-server-close
Finally, specify the frontend and backend settings to manage connections between HAProxy and MAAS:
frontend maas
retries 3
option redispatch
default_backend maas
backend maas
timeout server 90s
balance source
hash-type consistent
Apply these changes by restarting HAProxy:
Optional features like HAProxy logging^ can also be enabled, depending on your needs.
You can alternatively bypass SSL^ in HAProxy or implement native TLS on your MAAS UI without HAProxy.
Logging
Four types of log files can assist in pinpointing security problems:
- Firewall logs
- Web server logs
- MAAS log files
- System log files
This guide offers insights and references for each category.
Firewalls
Ubuntu’s Uncomplicated Firewall (UFW) serves as a front-end for iptables. To secure your MAAS setup, regularly review logs located in /var/log/ufw*
Identifying security red flags in UFW and iptables logs is more of an art than a science. However, here are some key patterns to help:
Be wary of traffic probing ports not linked to any application service. Such behaviour often signifies a port scanner in action.
Cross-reference unusual port numbers against databases of known hacker tools.
Repeated, failed access attempts from the same domain, IP, or subnet suggest malicious intent.
Messages from within your network may indicate a Trojan horse at play.
Web server
To analyse web server activity, employ a log analysis tool or inspect raw logs stored in paths like /var/log/httpd/
or /var/log/apache2
. Things to keep an eye on include:
- Multiple, rapid-fire requests
- Multiple failed login attempts
- Requests for non-existent pages
- Signs of SQL injection and Web shell attempts
MAAS logs
Pkg Fmt | Look for failed logins in… |
Snap | /var/snap/maas/common/log/regiond.log |
Packages | /var/log/maas/regiond.log |
For example, a legitimate login request might resemble:
2020-03-31 21:17:56 regiond: [info] 10.132.172.1 GET /MAAS/accounts/login/ HTTP/1.1 --> 200 OK
PostgreSQL security
PostgreSQL contains secrets, and should be encrypted for maximum protection. You should consider full disk encryption ^. Also recommended is TLS encryption between MAAS and PostgreSQL ^.
Other steps
In addition to the items mentioned above, you should be aware of a few other ways to harden MAAS.
Good passwords
You should pick good passwords and store them securely (e.g. in a KeePassX password database). Perform user administration only via the web UI. Only share the maas
and root
user passwords with administrators.
Permissions
MAAS configuration files should be set to have permission 640
: readable by logins belonging to the maas
group and writeable only by the root
user. Currently, the regiond.conf
file contains the login credentials for the PostgreSQL database used by MAAS to keep track of all machines, networks, and configuration.
Pkg Fmt | chmod 640 on files… | Final Perms | Add’l Info |
Snap | /var/snap/maas/current/regiond.conf |
-rw-r----- |
About snap security |
/var/snap/maas/current/rackd.conf |
-rw-r----- |
Packages | /etc/maas/rackd.conf/regiond.conf |
-rw-r----- |
/etc/maas/rackd.conf/rackd.conf |
-rw-r----- |
snap security
Snaps are fully confined or ‘sandboxed,’ offering inherent security for the enclosed application. For more detailed information, see this snap blog^.
Shared secrets
As a MAAS administrator, it’s crucial to avoid storing secrets associated with your MAAS instance in the database. This includes secrets like the OMAPI key and the RPC secret.
HashiCorp Vault
Beginning with version 3.3, MAAS secrets are stored in HashiCorp Vault.
Vault employs identity for securing secrets and encryption keys. Its core component is the kv
secrets engine, which utilises key-value pairs to store secrets within an encrypted storage managed by Vault. You can explore more about secrets engines if you’re interested.
Vault safeguards the secrets engine using a barrier view, creating a folder with a randomly-generated UUID as the absolute root directory for that engine. This prevents the engine from accessing secrets outside its UUID folder.
For detailed information, it’s recommended to refer to the Vault documentation and consider Vault certification.
Security consulting
If you need help implementing MAAS security, please contact us. We will be happy to assist you in arranging security consulting appropriate to your needs.
