- General availability kernels
- Hardware enablement kernels
- Hardware enablement kernels (pre-release)
- Low latency kernels
This article explains each of these kernels, and offers instructions and further references regarding their use.
Seven questions you may have:
- What is a general availability kernel?
- What is a hardware enablement kernel?
- What is a pre-release hardware enablement kernel?
- What is a low latency kernel?
- How do I set a minimum kernel for enlistment and commissioning?
- How to I set a minimum deploy kernel for a machine?
- How do I set a specific kernel during machine deployment?
ga-<version>
: The GA kernel reflects the major kernel version of the shipped Ubuntu release. For example, ‘ga-16.04’ is based on the ‘generic’ 4.4 Ubuntu kernel. As per Ubuntu policy, a GA kernel will never have its major version upgraded until the underlying release is upgraded.
Before MAAS 2.1 on Xenial, HWE kernels are referred to by the notation hwe-<release letter>
. So, to install the Yakkety HWE kernel on Xenial, the hwe-y
kernel is used. By default, when using the web UI, MAAS imports all available HWE kernels along with its generic boot images. So if you are importing Trusty images, then the following HWE kernels are included: hwe-u
, hwe-v
, hwe-w
, hwe-x
(presuming the Xenial HWE kernel is available).
In MAAS 2.1, starting with Xenial kernels, the notation has changed. The following is used to refer to the latest HWE kernel available for Xenial: hwe-16.04
MAAS denotes the edge kernel like this: hwe-<version>-edge
Low latency kernels
hwe-x-lowlatency
: the Xenial low latency HWE kernel for Trusty -
ga-16.04-lowlatency
: the low latency GA kernel for Xenial -
hwe-16.04-lowlatency
: the low latency HWE kernel for Xenial
Using kernels
- globally (default minimum enlistment and commissioning kernel)
- per machine (minimum deploy kernel)
- per machine during deployment (specific deploy kernel)
Set a default minimum kernel for enlistment and commissioning
The command option default_min_hwe_kernel
appears to apply to only HWE kernels but this is not the case.
Set a minimum deploy kernel for a machine
Set a specific kernel during machine deployment
The operation will fail if the kernel specified by hwe_kernel
is older than the kernel (possibly) given by default_min_hwe_kernel
. Similarly, it will not work if the kernel is not available for the given distro series (such as ‘hwe-16.10’ for ‘xenial’).
The command option hwe_kernel
