- If you place the machine on a connected network, and the machine is configured to netboot, MAAS will automatically enlist it.
- If you add a machine manually, MAAS will automatically commission it.
Four or five questions you may have:
- How does enlistment work?
- How do VM host nodes work?
- How do I add virtual machines?
- How do I add a machine manually?
- How do I add a machine via a chassis?
Configuring a computer to boot over PXE is done via its BIOS, often referred to as ânetbootâ or ânetwork bootâ.
Once MAAS is working to the point of adding machines, youâll probably want to understand statuses and actions. See Node statuses and Machine actions respectively.
How enlistment works
When MAAS enlists a machine, it first contacts the DHCP server, so that the machine can be assigned an IP address. An IP address is necessary to download a kernel and initrd via TFTP, since these functions canât accept domain names. Once the machine has a bootable kernel, MAAS boots it:
After the enlistment process, MAAS places the machine in the âReadyâ state. âReadyâ is a holding state for machines that are enlisted (or commissioned), waiting to be deployed when needed.
Typically, the next step will be to commission the machine. As an alternative to enlistment, an administrator can add a machine manually (see below). Typically this is done when enlistment doesnât work for some reason. Note that when you manually add a machine, MAAS automatically commissions the machine as soon as youâve added it.
Add a machine manually
On the âMachinesâ page of the web UI, click the âAdd hardwareâ button and then select âMachineâ.
Fill in the form and hit âSave machineâ. In this example, you are adding an IPMI machine:
The fields on the âAdd machineâ screen include the following items:
Machine name: This field is used to identify the machine to the user. It can be set to anything, though it is often set to the MAC address of the machine in question. This field is optional, in that MAAS will assign a unique, nonsense name if you leave it blank. You can change this nonsense name later, if desired.
Domain: This field sets the domain name of the domain managed by MAAS. It can be set to anything; MAAS assigns the domain name âmaasâ by default.
Architecture: This field refers to the architecture of the machine being added.
Minimum Kernel: This field supplies a drop-down of possible kernels available for deployment on this machine.
Zone: This field allows you to set the availability zone, selected from AZs that you have already created (if any).
Resource pool: This field allows you to set the resource pool for this machine, selected from pools you have already created (if any).
MAC Address: You should fill in this field with the MAC address of the machine you are adding. Note that the MAC address entered here must use a colon (":") separator, although some MAC addresses are written with dash ("-") separators.
- Power type: You must select the power type supported by the machine you are adding, and fill in additional required fields that appear. See Power management for details on the available power types and the relevant parameters for each type.
The network card on your server must be able to support PXE, i.e., your NIC â whether independent or integrated on a motherboard â must have a boot PROM that supports network booting. Youâll need to consult the documentation for the machine in question to determine this.
You usually have to interrupt the boot process and enter the BIOS/UEFI menu to configure the network cardâs PXE stack. Again, you may need to consult your machineâs documentation to pin down this step.
BMC enlistment
IPMI machines
Non-IPMI machines
Add a machine via a chassis
Use the chassis feature to add multiple machines at once. To do this, instead of selecting âMachineâ as above, choose âChassisâ from the drop-down menu. In the following example, MAAS will add all available VMs from the given virsh address:
