Using image streams (deb/2.7/ui)
2.7 2.8 2.9 3.0
Five questions you may have:
  2. What is the stable stream?
Candidate stream
Stable stream
Sunset of "daily" stream
Changing the stream - UI
Changing the stream - API/CLI
