Resource pools (deb/2.7/UI)
Six questions you may have:
  1. How can I add a resource pool?
  2. How can I delete a resource pool?
  3. How do I add a node to a resource pool?
  4. How do I remove a node from a resource pool?
  5. How do I add a VM host to a resource pool?
  6. How do I remove a VM host from a resource pool?
Add a resource pool
Deleting a resource pool
Removing a machine from a resource pool
Add a VM host to a resource pool
Removing a VM host from a resource pool
