VM hosting (snap/2.8/CLI)
MAAS VM hosts allow for the dynamic composition of nodes from a pool of available hardware resources (e.g. disk space, memory, cores). You can create virtual machines (VMs) as needed within the limits of your resources, without concern for physical hardware. MAAS currently supports VM hosts and VMs created via libvirt. MAAS also supports LXD VMs and VM hosts as a Beta feature.
Five questions you may have:
  1. What is a VM host?
  2. Which VM host should I use: LXD or KVM?
  3. How do I make LXD available for hosting?
  4. How do I set up SSH for use by libvirt?
  5. How do I add a VM host?
VM hosts are particularly useful for Juju integration, allowing for dynamic allocation of VMs with custom interface constraints. Alternatively, if you would like to use MAAS to manage a collection of VMs, the robust web UI allows you to easily create and manage VMs, logically grouped by VM host. Six conspicuous features include:
  1. Juju integration
  2. At-a-glance visual tools for easy resource management
  3. Set overcommit ratios for physical resources such as CPU and RAM
  4. Assign VMs to resource pools to segregate your VMs into logical groupings
  5. Track VM host storage pool usage and assign default storage pools
  6. Create VMs on multiple networks, specified by space, subnet, VLAN, or IP address
This section will lead you through the creation, usage, and management of VM hosts. Note that, as LXD VM hosts are still in Beta, some screen terminology has not yet been changed to reflect “VM host” instead of “KVM.” You will still use the “KVM” tab on the top of the MAAS dashboard to reach the VM host functionality, and you may see buttons which refer to “Add KVM,” for example, instead of “Add VM host.” Rest assured that the Beta LXD VM host functionality is fully available through these channels.
What is a VM host?
Simply put, a VM host is a machine which is designated to run virtual machines (VMs). A VM host divides its resources (CPU cores, RAM, storage) among the number of VMs you want to create, based on choices that you make when creating each VM. It is also possible to overcommit resources – that is, use more resources than the VM host actually has available – as long as you use the VMs carefully. Once MAAS has enlisted, commissioned, and acquired a newly-added machine, you can deploy it as a VM host.
LXD VM host (Beta) vs. libvirt
Libvirt KVMs and LXD VMs are both based on the same underlying virtualisation technology, QEMU. Unlike libvirt KVMs, though, LXD VMs can be managed without requiring SSH access to the VM host. LXD are remotely accessed via secure HTTP transport, which provides better security for LXD-based VMs. In addition, LXD has a better API, and is part of a much larger constellation of enterprise software, offering a wider range of future features and use cases.
Make LXD available for VM hosting (Beta)
Assuming that you want to use LXD VM hosts – currently a Beta feature – you need to install the correct version of LXD. Prior to the release of Ubuntu 20.04 LXD was installed using Debian packages. The Debian packaged version of LXD is too old to use with MAAS. If this is the case, you’ll need to remove the LXD Debian packages and install the Snap version. Note that you cannot install both Debian and snap versions, as this creates a conflict.
Reading package lists... Done
Building dependency tree
$ sudo apt-get autoremove -y
$ sudo snap install lxd
Refreshing LXD on 20.04
$ sudo snap refresh
All snaps up to date.
Initialise LXD prior to use
$ sudo lxd init
  1. Would you like to use LXD clustering? (yes/no) [default=no]: no - MAAS does not support LXD clusters in this Beta version.
  2. Name of the storage back-end to use (btrfs, dir, lvm, zfs, ceph) [default=zfs]: dir - Beta testing has primarily been with dir; other options should work, but less testing has been done, so use at your own risk.
  3. Would you like to connect to a MAAS server? (yes/no) [default=no]: no - When LXD is connected to MAAS containers or virtual machines created by LXD will be automatically added to MAAS as devices. This feature should work, but has limited testing in this Beta version.
Again:
