Seven questions you may have:
- How does MAAS communication work?
- How do I install a rack controller?
- How do I list rack controllers?
- How do I configure MAAS for multiple API servers?
- How do I unregister a rack controller?
- How do I move a rack controller from one MAAS instance to another?
- What are the potential dangers of moving a rack controller?
Install a rack controller
sudo maas-rack register --url $MAAS_URL --secret $SECRET
The $SECRET is stored in file /var/lib/maas/secret
on the API server.
Note that on the UI, you can find complete instructions for adding a rack controller under the “Controllers” tab. Simply click on the button labeled, “Add rack controller” and choose the instructions relevant to your build model (snap or packages). The commands there will already include the correct MAAS URL and secret, so you can cut and paste them at the command line.
List rack controllers
You can also list and confirm all registered rack controllers via the CLI; select the “Packages 2.7 CLI” link at the top of the page to find out how. Note that you will need multiple rack controllers to achieve specific high availability configurations.
Unregister a rack controller
where the secret is found in /var/lib/maas/secret
Using the same system as a rack controller and a VM host: While not forbidden or inherently dangerous, using the same machine as both a rack controller and a VM host may cause resource contention and poor performance. If the resources on the system are not more than adequate to cover both tasks, you may see slowdowns (or even apparent “freeze” events) on the system.
Moving a rack controller from one version of MAAS to another: MAAS rack controller software is an integral part of each version of MAAS. If you delete a rack controller from, say, a 2.6 version of MAAS, and attempt to register that 2.6 version of the rack controller code to, say, a 2.9 version of MAAS, you may experience errors and potential data loss. Using the above example, if you are running both a VM host and a rack controller for MAAS 2.6 on one system, and you suddenly decide to delete that rack controller from 2.6 and attempt to register the same code to a 2.9 MAAS, the VM host may fail or disappear. This will possibly delete all the VMs you have created or connected to that VM host – which may result in data loss. This action is not supported.
Connecting one instance of a rack controller to two instances of MAAS, regardless of version: Trying to connect a single rack controller to two different instances of MAAS can result in all sorts of unpredictable (and potentially catastrophic) behavior. It is not a supported configuration.
