Region and rack controllers balance the load and execute failover, automatically, as part of normal operations. This article will help you understand how to take advantage of these built-in features.
Enter HA mode
To enable high availability, just install multiple rack controllers; the rest is automatic. MAAS will immediately begin to load balance:
- racks to regions.
- rack controller connection count.
- region worker processes.
Every rack-to-region connection initiates a re-balancing loop. Re-balancing is also done at various other opportune times. For example, if a network change happens (like toggling DHCP or changing a VLAN), MAAS will also redistribute load.
HA BMC
You can also enable HA for BMC control (node power cycling) just by adding a second rack controller. MAAS will automatically identify which rack controller is responsible for a BMC, continuously balancing the connections.
HA DHCP
You can enable highly-available DHCP services by using MAAS-managed DHCP, and adding rack controllers. This DHCP HA affects the way MAAS manages nodes, including enlistment, commissioning and deployment. It enables primary and secondary DHCP instances to serve the same VLAN. This VLAN replicates all lease information is between rack controllers, so there’s a bit of performance boost for large networks.
MAAS DHCP automatically creates failover peers, using mostly standard parameters:
failover peer "failover-partner" {
primary;
address dhcp-primary.example.com;
peer address dhcp-secondary.example.com;
max-response-delay 60;
max-unacked-updates 10;
mclt 3600;
split 255;
load balance max seconds 3;
secondary;
peer address dhcp-primary.example.com;
Note that the only difference from a standard 50/50 split (split 128
) is that the primary DHCP server answers any requests that it can (split 255
), within the maximum response delay of 60 seconds and an unacknowledged update count of 10. In this sense, highly-available MAAS DHCP fails over only when absolutely necessary.
If you are enabling DHCP for the first time after adding a second rack controller, please read Enabling DHCP. On the other hand, if you have already enabled DHCP on your initial rack controller, you’ll need to reconfigure DHCP to get optimum results.
Update DHCP (UI)
To reconfigure DHCP after adding a new rack controller, select Subnets > VLAN > Reconfigure DHCP. Confirm that you can see the second rack controller under Secondary controller and select Reconfigure DHCP.
Update DHCP (CLI)
To reconfigure DHCP after adding a new rack controller, use the following sequence of commands:
vid=$(maas maas subnets read | jq -r '.[] | select(.cidr == "10.0.0.0/24") | .vlan.vid')
fabric_name=$(maas maas subnets read | jq -r '.[] | select(.cidr == "10.0.0.0/24") | .vlan.fabric')
query=".[] | select(.name == \"$fabric_name\") | .id"
fabric_id=$(maas maas fabrics read | jq "$query")
maas maas ipranges create type=reserved start_ip=10.0.0.3 end_ip=10.0.0.49
maas maas ipranges create type=dynamic start_ip=10.0.0.50 end_ip=10.0.0.99
maas maas vlan update ${fabric_id} ${vid} primary_rack=$(hostname) dhcp_on=true
Be sure to substitute the sample values for those of your own environment.
Multiple endpoints
MAAS will automatically discover and track all reachable region controllers in a single cluster of rack controllers It will also attempt to automatically connect to them if the one in use becomes inaccessible. Administrators can alternatively specify multiple region-controller endpoints for a single rack controller by adding entries to /var/snap/maas/current/rackd.conf
(if using Snaps) or /etc/maas/rackd.conf
(if using packages). For example:
maas_url:
- http://<ip 1>:<port>/MAAS/
- http://<ip 2>:<port>/MAAS/
HA regions
Implementing highly-available region control is relatively simple. Load balancing is optional, but is highly recommended.
HA PostgreSQL
MAAS stores all state information in the PostgreSQL database. It is therefore recommended to run it in HA mode. Configuring HA for PostgreSQL is external to MAAS. You will, therefore, need to study the PostgreSQL documentation↗
and implement the variant of HA that makes you feel most comfortable.
Each region controller uses up to 40 connections to PostgreSQL in high load situations. Running two region controllers requires no modifications to the max_connections
in postgresql.conf
. More than two region controllers require that max_connections
be adjusted to add 40 more connections per added region controller.
You can also use Ansible to set up HA PostgreSQL.
HA API services
Setting up high-availability using snaps is relatively easy:
- Set up PostgreSQL for high-availability as explained above. PostgreSQL should run outside of the snap.
- Install the MAAS snap on each machine you intend to use as a rack or region controller. You’ll need the MAAS shared secret, located here,
/var/snap/maas/common/maas/secret
, on the first region controller you set up. - Initialise the snap as a
rack
orregion
controller.
Note that if you intend to use a machine as a region controller, you’ll need to tell MAAS how to access your PostgreSQL database host with the following arguments:
--database-host DATABASE_HOST
--database-name DATABASE_NAME
--database-user DATABASE_USER
--database-pass DATABASE_PASS
Please see Region controllers and Multiple region endpoints for more information about how to install and configure rack controllers for multiple region controllers, when using packages.
Load balancing the API
You can add load balancing with HAProxy↗
load-balancing software to support multiple API servers. In this setup, HAProxy provides access to the MAAS web UI and API.
Pro tip: If you happen to have Apache running on the same server where you intend to install HAProxy, you will need to stop and disable
apache2
, because HAProxy binds to port 80.
Install HAProxy
sudo apt install haproxy
Set up HAProxy
Configure each API server’s load balancer by copying the following into /etc/haproxy/haproxy.cfg
(see the upstream configuration manual (external link)↗
as a reference). Replace $PRIMARY_API_SERVER_IP and $SECONDARY_API_SERVER_IP with their respective IP addresses:
frontend maas
bind *:80
retries 3
option redispatch
option http-server-close
default_backend maas
backend maas
timeout server 90s
balance source
hash-type consistent
where maas-api-1
and maas-api-2
are arbitrary server labels.
Moving racks
In effect, there is no such action as moving a rack controller, although you can delete a rack controller from one MAAS and reinstantiate the same controller (binary-wise) on another MAAS instance. First, delete the rack controller. In the UI, find Controllers, select the rack controller you with to delete, choose Take action and select Delete. You will be asked to confirm.
If you’re using the CLI, follow this procedure:
where $PROFILE
is your admin profile name, and $SYSTEM_ID
can be found by examining the output of the command:
maas $PROFILE rack-controllers read
Next, you must register a new rack controller, which is always done from the command line:
where the secret is found in /var/lib/maas/secret
(if using Debian packages) or /var/snap/maas/common/maas/secret
(if using Snaps).
Avoiding move issues
Using the same system as a rack controller and a VM host: While not forbidden or inherently dangerous, using the same machine as both a rack controller and a VM host may cause resource contention and poor performance. If the resources on the system are not more than adequate to cover both tasks, you may see slowdowns (or even apparent “freeze” events) on the system.
Moving a rack controller from one version of MAAS to another: MAAS rack controller software is an integral part of each version of MAAS. If you delete a rack controller from, say, a 2.6 version of MAAS, and attempt to register that 2.6 version of the rack controller code to, say, a 2.9 version of MAAS, you may experience errors and potential data loss. Using the above example, if you are running both a VM host and a rack controller for MAAS 2.6 on one system, and you suddenly decide to delete that rack controller from 2.6 and attempt to register the same code to a 2.9 MAAS, the VM host may fail or disappear. This will possibly delete all the VMs you have created or connected to that VM host – which may result in data loss. This action is not supported.
Connecting one instance of a rack controller to two instances of MAAS, regardless of version: Trying to connect a single rack controller to two different instances of MAAS can result in all sorts of unpredictable (and potentially catastrophic) behaviour. It is not a supported configuration.
