Six questions you may have:
- How does UEFI booting work?
- What kind of storage layouts are available?
- How do I set global storage layouts?
- How do I set per-machine storage layouts?
- What storage modifications can I make at the filesystem level?
- How can I erase a disk?
UEFI
Every layout type supports a machine booting with UEFI. In such a case, MAAS automatically creates an EFI boot partition (/boot/efi
). Other than setting the machine to boot from UEFI, the user does not need to take any additional action.
The EFI partition, if created, will be the first partition (sda1
) and will have a FAT32 filesystem with a size of 512 MB.
Layouts
There are three layout types:
- Flat layout
- LVM layout
- bcache layout
The layout descriptions below will include the EFI partition. If your system is not using UEFI, regard sda2
as sda1
(with an additional 512 MB available to it).
Flat layout
With the Flat layout, a partition spans the entire boot disk. The partition is formatted with the ext4 filesystem and uses the /
mount point:
Name | Size | Type | Filesystem | Mount point |
sda | - | disk | ||
sda1 | 512 MB | part | FAT32 | /boot/efi |
sda2 | rest of sda | part | ext4 | / |
boot_size
: Size of the boot partition on the boot disk. Default is 0, meaning not to create the boot partition. The ‘/boot’ will be placed on the root filesystem. -
root_device
: The block device on which to place the root partition. The default is the boot disk. -
root_size
: Size of the root partition. Default is 100%, meaning the entire size of the root device.
LVM layout
The LVM layout creates the volume group vgroot
on a partition that spans the entire boot disk. A logical volume lvroot
is created for the full size of the volume group; is formatted with the ext4 filesystem; and uses the /
mount point:
sda | - | disk | ||
sda2 | rest of sda | part | lvm-pv(vgroot) | |
lvroot | rest of sda | lvm | ext4 | / |
vgroot | rest of sda | lvm |
boot_size
root_device
root_size
: Size of the root partition. Default is 100%, meaning the entire size of the root device. -
vg_name
: Name of the created volume group. Default isvgroot
lv_name
: Name of the created logical volume. Default islvroot
lv_size
: Size of the created logical volume. Default is 100%, meaning the entire size of the volume group.
bcache layout
A bcache layout will create a partition that spans the entire boot disk as the backing device. It uses the smallest block device tagged with ‘ssd’ as the cache device. The bcache device is formatted with the ext4 filesystem and uses the /
mount point. If there are no ‘ssd’ tagged block devices on the machine, then the bcache device will not be created, and the Flat layout will be used instead:
sda | - | disk | ||
sda2 | rest of sda | part | bc-backing | |
sdb (ssd) | - | disk | ||
sdb1 | 100% of sdb | part | bc-cache | |
bcache0 | per sda2 | disk | ext4 | / |
boot_size
root_device
: The block device upon which to place the root partition. The default is the boot disk. -
root_size
cache_device
: The block device to use as the cache device. Default is the smallest block device tagged ssd. -
cache_mode
: The cache mode to which MAAS should set the created bcache device. The default iswritethrough
cache_size
: The size of the partition on the cache device. Default is 100%, meaning the entire size of the cache device. -
cache_no_part
: Whether or not to create a partition on the cache device. Default is false, meaning to create a partition using the givencache_size
. If set to true, no partition will be created, and the raw cache device will be used as the cache.
VMFS6 layout
Name | Size | Type | Use |
sda | - | disk | |
sda1 | 3 MB | part | EFI |
sda2 | 4 GB | part | Basic Data |
sda3 | Remaining | part | VMFS Datastore 1 |
sda4 | - | skipped | |
sda5 | 249 MB | part | Basic Data |
sda6 | 249 MB | part | Basic Data |
sda7 | 109 MB | part | VMware Diagnostic |
sda8 | 285 MB | part | Basic Data |
sda9 | 2.5 GB | part | VMware Diagnostic |
root_device
: The block device upon which to place the root partition. Default is the boot disk. -
root_size
: Size of the default VMFS Datastore. Default is 100%, meaning the remaining size of the root disk.
Blank layout
Setting layouts
Machine layout
Final storage modifications
