About MAAS (deb/2.7/CLI)
Four questions you might have:
  1. What is MAAS?
  2. What does MAAS offer me?
  3. Can MAAS co-locate key components to conserve resources?
  4. How does MAAS work?
What is MAAS?
Tell me about PXE booting
What MAAS offers
MAAS integrates all the tools you need into a smooth system-management experience. It includes the following eleven features:
  1. Ubuntu, CentOS, Windows, and RHEL installation support
  2. open-source IP address management (IPAM)
  3. high availability (optional)
  4. IPv6 support
  5. inventory of components
  6. DHCP and DNS for other devices on the network
  7. DHCP relay integration
  8. VLAN and fabric support
  9. NTP for the entire infrastructure
  10. hardware testing
  11. composable hardware support
Colocation of key components
How MAAS works
When acquiring machines from the API/CLI, you can specify requirements (“constraints”). Common constraints are memory, CPU cores, connected networks, and assigned physical zone.
