Tips tricks and traps (deb/2.8/CLI)
What would you like to do?
  5. Resolve MAAS/LXD DNS & DHCP conflicts/network issues
sudo snap stop maas
sudo -u postgres \
If you get into a situation where MAAS and LXD are both managing DNS on your MAAS network, there’s a simple fix. You can turn off LXD’s DNS management with the following command:
You should also disable DHCP on IPv4 and IPv6 withing LXD:
lxc network set $LXD_BRIDGE_NAME ipv4.dncp=false
Once you’ve done this, you can check your work with the following command:
lxc network show $LXD_BRIDGE_NAME
Basic machine list
#!/bin/bash
 #!/bin/bash
