Snap >>> | UI/2.7 | UI/2.8 | CLI/2.7 | CLI/2.8 |
Packages >>> | UI/2.7 | UI/2.8 | CLI/2.7 | CLI/2.8 |
- How do I upgrade my existing MAAS?
- How do I install and configure MAAS?
- How do I add machines to MAAS?
- How do I deploy and manage machines with MAAS?
Upgrade an existing MAAS
It’s easy to upgrade your 2.7 snap to 2.8 – but you’ll want to confirm whether you’re running MAAS in a single node (region+rack) or on multiple nodes (separate region and rack controllers).
For a region+rack configuration
Upgrade your 2.7 snap to 2.8 with this command:
$ sudo snap refresh --channel=2.8 maas
After entering your password, the snap will refresh from the 2.8 channel. You will not need to re-initialize MAAS.
For a multi-node MAAS deployment
If you are using a multi-node maas deployment with separate regions and racks, you should first run this command on each of your rack nodes:
Finally, run the same command on your region node(s).
- How do I prepare to install MAAS?
- How do I install MAAS?
- How do I initialize MAAS?
- How do I configure MAAS and get it running?
Preparing to install MAAS
- What are the requirements for a test environment?
- What are the requirements for a production environment?
- What setup steps should I complete before installation?
MAAS host requirements
Memory (MB) | CPU (GHz) | Disk (GB) | |
Region controller (minus PostgreSQL) | 512 | 0.5 | 5 |
PostgreSQL | 512 | 0.5 | 5 |
Rack controller | 512 | 0.5 | 5 |
Ubuntu Server (including logs) | 512 | 0.5 | 5 |
Region controller (minus PostgreSQL) | 2048 | 2.0 | 5 |
PostgreSQL | 2048 | 2.0 | 20 |
Rack controller | 2048 | 2.0 | 20 |
- the number of connecting clients (client activity)
- how you decide to distribute services
- whether or not you use high availability/load balancing.
- the number of images that you choose to store (disk space affecting PostgreSQL and the rack controller)
Setting up for MAAS
Disable bind9 - If
bind9
is running on the system where you’re going to host MAAS, you need to disable it. The bind9 daemon interferes with MAAS, producing some unusual and hard-to-debug errors. You can see if it’s running with the commandps aux | grep named
. - Set your machines to netboot - MAAS uses PXE to remotely boot your machines via their NICs, so you’ll need to have your machines set to netboot, or MAAS can’t access and use them.
- Turn on machines that should auto-enlist - If you want MAAS to find and enlist your machines automatically, you need to turn them on.
- OR gather the UUIDs and MAC addresses for your machines - If you’re going to manually enroll machines, you’ll need this information.
- AND determine the power type - If you’re manually enrolling machines, you’ll also want to be able to tell MAAS how power them up. Follow the link to learn more about power types.
If you have installed bind9
or have it running, you will need to uninstall it before installing MAAS. You can check with ps aux | grep named
to see if it’s running. The bind9
daemon interferes with MAAS operation and creates a number of unusual, hard-to-debug errors – but don’t worry, MAAS provides DNS and can work with existing DNS servers.
Installing MAAS
After entering your password, the snap will download and install from the 2.8 channel – though MAAS needs initialising before it’s ready to go.
Initialising MAAS
MAAS 2.8 supports essentially three initialisation modes and two configurations: a test or proof-of-concept configuration, and a production configuration. MAAS 2.8 separates the PostgreSQL database from the MAAS snap for scalability reasons, so the steps are a bit different than previous versions. In the case of the production configuration, native PostgreSQL on the localhost is used for the MAAS database. For the test configuration, a PostgreSQL snap is provided to encapsulate the test database. Read on to determine your desired modes before initialising.
- What are the initialisation modes for MAAS 2.8?
- How do I initialise MAAS in a test configuration?
- How do I initialise MAAS for production?
MAAS initialisation modes
Mode | Region | Rack | Database | Description |
all * |
X | X | X | Deprecated (see warning below) |
region |
X | Region API server only | ||
rack |
X | Rack controller only | ||
region+rack |
X | X | Region API server and rack controller | |
none |
Deinitializes MAAS and stops services |
all mode being deprecated: The MAAS initialisation mode “all” is deprecated in MAAS version 2.8.0 and will be removed in MAAS version 2.9.0.
Initialising MAAS as a test configuration
We want to provide a more compact version for those who may be testing MAAS. To achieve this, we’re providing a separate snap, called maas-test-db
, which provides a PostgreSQL database for use in testing and evaluating MAAS. The following instructions will help you take advantage of this test configuration.
Once MAAS is installed, you can use the --help
flag with maas init
to get relevant instructions:
$ sudo maas init --help
optional arguments:
run modes:
region+rack Both region and rack controllers
region Region controller only
rack Rack controller only
We’ll quickly walk through these instructions to confirm your understanding. First, install the maas-test-db
snap:
$ maas-test-db.psql
psql (10.6)
Type "help" for help.
postgres=# \l
This will produce a list of databases, one of which will be maasdb
, owned by maas
. Note that this database is still empty because MAAS is not yet initialized and, hence, is not yet using the database. Once this is done, you can run the maas init
command:
MAAS has been set up.
sudo maas configauth
sudo maas createadmin
Let’s assume you just want a local testing user named admin
$ sudo maas createadmin
Username: admin
Password: ******
Again: ******
Email: admin@example.com
At this point, MAAS is basically set up and running. You can confirm this with sudo maas status
. If you need an API key, you can obtain this with sudo maas apikey --username yourusername
. Now you will be able to test and evaluate MAAS by going to the URL you entered or accepted above and entering your admin
username and password.
You will need to install PostgreSQL on the machine where you want to keep the database. This can be the same machine as the MAAS region/rack controllers or a totally separate machine. If PostgreSQL (version 10 or better) is already running on your target machine, you can skip this step. To install PostgreSQL, run these commands:
sudo apt update -y sudo apt install -y postgresql
You want to make sure you have a suitable PostgreSQL user, which can be accomplished with the following command, where
$MAAS_DBUSER
is your desired database username, and$MAAS_DBPASS
is the intended password for that username. Note that if you’re executing this step in a LXD container (as root, which is the default), you may get a minor error, but the operation will still complete correctly.sudo -u postgres psql -c "CREATE USER \"$MAAS_DBUSER\" WITH ENCRYPTED PASSWORD '$MAAS_DBPASS'"
Create the MAAS database with the following command, where
$MAAS_DBNAME
is your desired name for the MAAS database (typically known asmaas
). Again, if you’re executing this step in a LXD container as root, you can ignore the minor error that results.sudo -u postgres createdb -O "$MAAS_DBUSER" "$MAAS_DBNAME"
Edit
/etc/postgresql/10/main/pg_hba.conf
and add a line for the newly created database, replacing the variables with actual names. You can limit access to a specific network by using a different CIDR than0/0
.host $MAAS_DBNAME $MAAS_DBUSER 0/0 md5
You can then initialise MAAS via the following command:
You should use localhost
for $HOSTNAME
if you’re running PostgreSQL on the same box as MAAS.
Checking MAAS service status
sudo maas status
bind9 RUNNING pid 7999, uptime 0:09:17
dhcpd STOPPED Not started
dhcpd6 STOPPED Not started
ntp RUNNING pid 8598, uptime 0:05:42
postgresql RUNNING pid 8001, uptime 0:09:17
proxy STOPPED Not started
rackd RUNNING pid 8000, uptime 0:09:17
regiond:regiond-0 RUNNING pid 8003, uptime 0:09:17
regiond:regiond-1 RUNNING pid 8008, uptime 0:09:17
regiond:regiond-2 RUNNING pid 8005, uptime 0:09:17
regiond:regiond-3 RUNNING pid 8015, uptime 0:09:17
tgt RUNNING pid 8040, uptime 0:09:15
The following demonstrates the region+rack
mode, a popular initialisation choice for MAAS:
maas
will ask for the MAAS URL:
Create first admin account:
Username: admin
Password: ******
Again: ******
MAAS URL
All run modes (except none
) prompt for a MAAS URL, interpreted differently depending on the mode:
region
: Used to create a new region controller. -
rack
: Used to locate the region controller.
Shared secret
Reinitialising MAAS
It is also possible to re-initialise MAAS to switch modes. For example, to switch from rack
to region
Additional `init` options
The init
command can takes optional arguments. To list them, as well as read a brief description of each, you can enter:
Logging in to MAAS
Adding admin SSH keys to MAAS
Setting up MAAS networking
Adding physical machines
Adding virtual machines
Commissioning machines
Acquiring machines
Deploying machines
Releasing deployed machines
Marking machines as broken
Access the web UI
Zones
Networking
Import boot images
Access the MAAS CLI
Enable DHCP
Users and SSH keys
Add a machine
Edit power type
Commission a machine
Deploy a machine
SSH to the machine
