Enabling MAAS 2.8 (snap/CLI)
Snap >>> UI/2.7 UI/2.8 CLI/2.7 CLI/2.8
Packages >>> UI/2.7 UI/2.8 CLI/2.7 CLI/2.8
Upgrade an existing MAAS
It’s easy to upgrade your 2.7 snap to 2.8 – but you’ll want to confirm whether you’re running MAAS in a single node (region+rack) or on multiple nodes (separate region and rack controllers).
For a region+rack configuration
Upgrade your 2.7 snap to 2.8 with this command:
$ sudo snap refresh --channel=2.8 maas
After entering your password, the snap will refresh from the 2.8 channel. You will not need to re-initialize MAAS.
For a multi-node MAAS deployment
If you are using a multi-node maas deployment with separate regions and racks, you should first run this command on each of your rack nodes:
Finally, run the same command on your region node(s).
Preparing to install MAAS
MAAS host requirements
PostgreSQL 512 0.5 5
Rack controller 512 0.5 5
PostgreSQL 2048 2.0 20
Rack controller 2048 2.0 20
  • A region controller (including PostgreSQL) installed on one host, with 4.5 GB memory, 4.5 GHz CPU, and 45 GB of disk space.
  • A duplicate region controller (including PostgreSQL) on a second host, also with 4.5 GB memory, 4.5 GHz CPU, and 45 GB of disk space.
  • A rack controller installed on a third host, with 2.5 GB memory, 2.5 GHz CPU, and 40 GB of disk space.
  • A duplicate rack controller on a fourth host, also with 2.5 GB memory, 2.5 GHz CPU, and 40 GB of disk space.
  • the number of connecting clients (client activity)
  • how you decide to distribute services
  • whether or not you use high availability/load balancing.
  • the number of images that you choose to store (disk space affecting PostgreSQL and the rack controller)
Setting up for MAAS
  • Disable bind9 - If bind9 is running on the system where you’re going to host MAAS, you need to disable it. The bind9 daemon interferes with MAAS, producing some unusual and hard-to-debug errors. You can see if it’s running with the command ps aux | grep named.
  • Set your machines to netboot - MAAS uses PXE to remotely boot your machines via their NICs, so you’ll need to have your machines set to netboot, or MAAS can’t access and use them.
  • Turn on machines that should auto-enlist - If you want MAAS to find and enlist your machines automatically, you need to turn them on.
  • OR gather the UUIDs and MAC addresses for your machines - If you’re going to manually enroll machines, you’ll need this information.
  • AND determine the power type - If you’re manually enrolling machines, you’ll also want to be able to tell MAAS how power them up. Follow the link to learn more about power types.
If you have installed bind9 or have it running, you will need to uninstall it before installing MAAS. You can check with ps aux | grep named to see if it’s running. The bind9 daemon interferes with MAAS operation and creates a number of unusual, hard-to-debug errors – but don’t worry, MAAS provides DNS and can work with existing DNS servers.
Installing MAAS
After entering your password, the snap will download and install from the 2.8 channel – though MAAS needs initialising before it’s ready to go.
Initialising MAAS
MAAS 2.8 supports essentially three initialisation modes and two configurations: a test or proof-of-concept configuration, and a production configuration. MAAS 2.8 separates the PostgreSQL database from the MAAS snap for scalability reasons, so the steps are a bit different than previous versions. In the case of the production configuration, native PostgreSQL on the localhost is used for the MAAS database. For the test configuration, a PostgreSQL snap is provided to encapsulate the test database. Read on to determine your desired modes before initialising.
MAAS initialisation modes
all* X X X Deprecated (see warning below)
rack X Rack controller only
none Deinitializes MAAS and stops services
all mode being deprecated: The MAAS initialisation mode “all” is deprecated in MAAS version 2.8.0 and will be removed in MAAS version 2.9.0.
Initialising MAAS as a test configuration
$ sudo maas init --help
optional arguments:
run modes:
$ maas-test-db.psql
psql (10.6)
Type "help" for help.
postgres=# \l
This will produce a list of databases, one of which will be maasdb, owned by maas. Note that this database is still empty because MAAS is not yet initialized and, hence, is not yet using the database. Once this is done, you can run the maas init command:
MAAS has been set up.
  sudo maas configauth
  sudo maas createadmin
$ sudo maas createadmin
Username: admin
Password: ******
Again: ******
Email: admin@example.com
  1. You will need to install PostgreSQL on the machine where you want to keep the database. This can be the same machine as the MAAS region/rack controllers or a totally separate machine. If PostgreSQL (version 10 or better) is already running on your target machine, you can skip this step. To install PostgreSQL, run these commands:
     sudo apt update -y
  2. You want to make sure you have a suitable PostgreSQL user, which can be accomplished with the following command, where $MAAS_DBUSER is your desired database username, and $MAAS_DBPASS is the intended password for that username. Note that if you’re executing this step in a LXD container (as root, which is the default), you may get a minor error, but the operation will still complete correctly.
     sudo -u postgres psql -c "CREATE USER \"$MAAS_DBUSER\" WITH ENCRYPTED PASSWORD '$MAAS_DBPASS'"
  3. Create the MAAS database with the following command, where $MAAS_DBNAME is your desired name for the MAAS database (typically known as maas). Again, if you’re executing this step in a LXD container as root, you can ignore the minor error that results.
     sudo -u postgres createdb -O "$MAAS_DBUSER" "$MAAS_DBNAME"
  4. Edit /etc/postgresql/10/main/pg_hba.conf and add a line for the newly created database, replacing the variables with actual names. You can limit access to a specific network by using a different CIDR than 0/0.
  5. You can then initialise MAAS via the following command:
Checking MAAS service status
sudo maas status
Create first admin account:
Username: admin
Password: ******
Again: ******
MAAS URL
Shared secret
Reinitialising MAAS
Additional `init` options
Logging in to MAAS
Adding admin SSH keys to MAAS
Setting up MAAS networking
Adding physical machines
Adding virtual machines
Commissioning machines
Acquiring machines
Deploying machines
Releasing deployed machines
Marking machines as broken
Access the web UI
Zones
Networking
Import boot images
Access the MAAS CLI
Enable DHCP
Users and SSH keys
Add a machine
Edit power type
Commission a machine
Deploy a machine
SSH to the machine
