Enabling MAAS 2.7 (snap/UI)
Snap >>> UI/2.7 UI/2.8 CLI/2.7 CLI/2.8
Packages >>> UI/2.7 UI/2.8 CLI/2.7 CLI/2.8
Upgrade an existing MAAS
Preparing to install MAAS
MAAS host requirements
PostgreSQL 512 0.5 5
Rack controller 512 0.5 5
PostgreSQL 2048 2.0 20
Rack controller 2048 2.0 20
  • A region controller (including PostgreSQL) installed on one host, with 4.5 GB memory, 4.5 GHz CPU, and 45 GB of disk space.
  • A duplicate region controller (including PostgreSQL) on a second host, also with 4.5 GB memory, 4.5 GHz CPU, and 45 GB of disk space.
  • A rack controller installed on a third host, with 2.5 GB memory, 2.5 GHz CPU, and 40 GB of disk space.
  • A duplicate rack controller on a fourth host, also with 2.5 GB memory, 2.5 GHz CPU, and 40 GB of disk space.
  • the number of connecting clients (client activity)
  • how you decide to distribute services
  • whether or not you use high availability/load balancing.
  • the number of images that you choose to store (disk space affecting PostgreSQL and the rack controller)
Setting up for MAAS
  • Disable bind9 - If bind9 is running on the system where you’re going to host MAAS, you need to disable it. The bind9 daemon interferes with MAAS, producing some unusual and hard-to-debug errors. You can see if it’s running with the command ps aux | grep named.
  • Set your machines to netboot - MAAS uses PXE to remotely boot your machines via their NICs, so you’ll need to have your machines set to netboot, or MAAS can’t access and use them.
  • Turn on machines that should auto-enlist - If you want MAAS to find and enlist your machines automatically, you need to turn them on.
  • OR gather the UUIDs and MAC addresses for your machines - If you’re going to manually enroll machines, you’ll need this information.
  • AND determine the power type - If you’re manually enrolling machines, you’ll also want to be able to tell MAAS how power them up. Follow the link to learn more about power types.
If you have installed bind9 or have it running, you will need to uninstall it before installing MAAS. You can check with ps aux | grep named to see if it’s running. The bind9 daemon interferes with MAAS operation and creates a number of unusual, hard-to-debug errors – but don’t worry, MAAS provides DNS and can work with existing DNS servers.
Installing MAAS
Initialising MAAS
sudo maas init region+rack
sudo maas createadmin
Create first admin account:
Username: admin
Password: ******
Again: ******
Email: admin@example.com
MAAS URL
Shared secret
Reinitialising MAAS
Additional `init` options
sudo maas init --help
snap-ui-2-8 snap-cli-2-8 -->
sudo snap install maas --channel=2.7
After entering your password, the snap will download and install from the 2.7.0 channel. However, MAAS needs initialising before it’s ready to go.
Initialisation
The next step involves initialising MAAS with a run mode. Selecting one of the following modes dictates what services will run on the local system:
all* X X X All services (see warning below)
rack X Rack controller only
none Deinitializes MAAS and stops services
all mode being deprecated: Configuring the MAAS snap in “all” mode will be deprecated in MAAS version 2.8.0 and removed in MAAS version 2.9.0.
To initialise MAAS and select a run mode, use the maas init command with the –mode argument.
Example
The following demonstrates the all mode, a popular initialisation choice for MAAS:
sudo maas init --mode all
A dialog will appear that will gather some basic information:
Username: admin
Password: ******
Again: ******
You will use the username and password to access the web UI. If you enter a Launchpad or GitHub account name with associated SSH key, MAAS will import them automatically.
MAAS URL
  • all, region+rack: Used to create a new region controller as well as to tell the rack controller how to find the region connntroller.
Shared secret
Reinitialising MAAS
To re-initialise MAAS, for example, to switch from rack to region:
sudo maas init --mode region
The init command can take a number of optional arguments. To list them all as well as read a brief description of each:
Configuration verification
After a snap installation of MAAS, you can verifiy the currently-running configuration with:
sudo maas config
Sample output (for mode ‘all’):
Mode: all
Settings:
maas_url=http://192.168.122.1:5240/MAAS
Service statuses
sudo maas status
Logging in to MAAS
Adding admin SSH keys to MAAS
Setting up MAAS networking
Adding physical machines
Adding virtual machines
Commissioning machines
Acquiring machines
Deploying machines
Releasing deployed machines
Marking machines as broken
Access the web UI
Zones
Networking
Import boot images
Access the MAAS CLI
Enable DHCP
Users and SSH keys
Add a machine
Edit power type
Commission a machine
Deploy a machine
SSH to the machine
