To use MAAS with Terraform, a provider is available. This guide gives an overview of data sources and resources accessible via this provider, without delving into the mechanics of Terraform or the MAAS Terraform provider.
The MAAS Terraform provider enables management of MAAS resources via Terraform’s CRUD tool. Each section in this document provides definitions and usage examples. For more about Terraform, consult the Terraform documentation or various available tutorials.
API linkages
To connect MAAS with Terraform, you’ll need both a standard HCL provider block and a provider API block. The former requires at least:
- A
sourceelement: “maas/maas”. - A
versionelement: “~>1.0”.
Here’s what the provider block might look like:
terraform {
required_providers {
maas = {
source = "maas/maas"
version = "~>1.0"
The provider API block includes credentials for MAAS access:
- API version
- API key
- API URL
Example:
provider "maas" {
api_version = "2.0"
api_key = "<YOUR API KEY>"
api_url = "http://127.0.0.1:5240/MAAS"
Data sources
The MAAS Terraform provider offers three main data sources focused on networking:
- Fabrics
- Subnets
- VLANs
Each data source comes with an HCL block that manages its corresponding MAAS element.
Fabrics
The fabric data source reveals minimal details, usually the fabric ID:
data "maas_fabric" "default" {
name = "maas"
Subnets
The subnet data source provides extensive attributes for an existing MAAS subnet. To declare one:
data "maas_subnet" "vid10" {
cidr = "10.10.0.0/16"
VLANs
The VLAN data source focuses on an existing MAAS VLAN. For instance:
data "maas_vlan" "vid10" {
fabric = data.maas_fabric.default.id
vlan = 10
Resources
For full details, refer to the Terraform HCL documentation.
