| 2.7 | 2.8 | 2.9 | 3.0 | |
| Snap | CLI ~ UI | CLI ~ UI | CLI ~ UI | CLI ~ UI |
| Packages | CLI ~ UI | CLI ~ UI | CLI ~ UI | CLI ~ UI |
Five questions you may have:
- What is the candidate stream?
- What is the stable stream?
- What happened to the daily stream?
- How do I change the stream with the UI?
- How do I change the stream with the CLI?
Candidate stream
Stable stream
Sunset of "daily" stream
Changing the stream - UI
Changing the stream - API/CLI
