Using image streams (snap/2.7/ui)
2.9 3.0
Snap CLI ~ UI CLI ~ UI
Packages CLI ~ UI CLI ~ UI
Five questions you may have:
  2. What is the stable stream?
Candidate stream
Stable stream
Sunset of "daily" stream
Changing the stream - UI
Changing the stream - API/CLI
