Five questions you may have:
- What is the candidate stream?
- What is the stable stream?
- What happened to the daily stream?
- How do I change the stream with the UI?
- How do I change the stream with the CLI?
Candidate stream
Stable stream
Sunset of "daily" stream
Changing the stream - UI
To switch to the candidate stream simply select “custom” on the images page, set the URL to http://images.maas.io/ephemeral-v3/candidate
, and click “Connect”
MAAS uses the stable stream by default. To switch back to it simply select maas.io
on the images page
Changing the stream - API/CLI
