How to use storage tags (deb/2.9/CLI)
This article explains:
How to discover the ID of your block device
| @tsv' | column -t
For example:
| @tsv' | column -t
system_id  block_device_id  path                    avail_size
qk4b3g     10               /dev/disk/by-dname/sda  0
The path component is printed to help you confirm that you are choosing the right block device, when there are several present. The avail-size column will tell you whether you can operate on that block device at all: If the available size is “0,” for example, you can’t set a block device tag on any part of that drive. Instead, you’d want to see something like this:
xn8taa     8                /dev/disk/by-dname/sda  1996488704
How to assign tags to a block device
For example:
If this command succeeds, it will display Success, followed by a JSON sequence describing the new state of the block device.
Not Found
How to remove tags from a block device
For example:
Note that if you try to remove a tag from a block device that is not available, that is, from a block device that is in use, you will get a result like this:
Not Found
How to list tags for all block devices
For example:
id  tags
8   hello  ssd  trinkoplinko
How to view tags for one block device
For example:
id  tags
9   20gig  ssd
10  250Gs  ssd
How to discover the ID of your partition
|@tsv' | column -t
For example:
|@tsv' | column -t
system_id  block_dev_id  part_id  path
xn8taa     8             67       /dev/disk/by-dname/sda-part1
The path component is printed to help you confirm that you are choosing the right partition, when there are several present.
How to assign tags to a partition
For example:
If this command succeeds, it will display Success, followed by a JSON sequence describing the new state of the partition.
Not Found
How to remove tags from a partition
For example:
Note that if you try to remove a tag from a partition that is not available, that is, from a partition that is in use, you will get a result like this:
Not Found
On the other hand, if you try to remove a tag that is not assigned to the partition you’ve chosen, MAAS will simply return Success, followed by a JSON sequence describing the current state of the partition.
How to list tags for all partitions
| @tsv' | column -t
For example:
| @tsv' | column -t
id  tags
54  farquar swap opendisk
67  foobar  farquar
97  foobar
How to view tags for one partition
To view tags for one partition, enter a command similar to this:
For example:
This command should produce output similar to this:
id  tags
67  foobar  farquar
