This article explains:
- How to create and assign block device tags
- How to remove and delete block device tags
- How to list block device and partition tags
- How to view block device tags
- How to view partition tags
- Go to the machine list:
- Select that machine that has the block-device you want to tag:
- Click on the “Storage” tab and focus on the block labelled “Available disks and partitions:”
- Click the drop-down arrow at the right end of the row containing the block device you want to tag. Choose the “Edit…” option (the wording may vary, e.g, “Edit physical…”). This will take you to an editing screen for that block device:
Add tags as desired.
Be sure to click on the “Save” button when you’re done.
- Select that machine that has the block-device with the tag you want to remove:
Delete tags by clicking the “X” next to them.
To see block device and partition tags in the UI, you can list all storage links by using the filter tool on the machine list. Here’s how:
- Select the “Filters” drop-down and open the section titled “Storage tags:”
- Select that machine that has the block device that interests you:
- Click on the “Storage” tab and check the page for tags:
