This article explains:
- How to discover the ID of your block device
- How to assign tags to a block device
- How to remove tags from a block device
- How to list tags for all block devices
- How to view tags for one block device
- How to discover the ID of your partition
- How to assign tags to a partition
- How to remove tags from a partition
- How to list tags for all partitions
- How to view tags for one partition
| @tsv' | column -t
For example:
| @tsv' | column -t
system_id block_device_id path avail_size
qk4b3g 10 /dev/disk/by-dname/sda 0
The path component is printed to help you confirm that you are choosing the right block device, when there are several present. The avail-size column will tell you whether you can operate on that block device at all: If the available size is “0,” for example, you can’t set a block device tag on any part of that drive. Instead, you’d want to see something like this:
xn8taa 8 /dev/disk/by-dname/sda 1996488704
For example:
If this command succeeds, it will display Success, followed by a JSON sequence describing the new state of the block device.
Not Found
For example:
Note that if you try to remove a tag from a block device that is not available, that is, from a block device that is in use, you will get a result like this:
Not Found
For example:
id tags
8 hello ssd trinkoplinko
For example:
id tags
9 20gig ssd
10 250Gs ssd
|@tsv' | column -t
For example:
|@tsv' | column -t
system_id block_dev_id part_id path
xn8taa 8 67 /dev/disk/by-dname/sda-part1
The path component is printed to help you confirm that you are choosing the right partition, when there are several present.
For example:
If this command succeeds, it will display Success, followed by a JSON sequence describing the new state of the partition.
Not Found
For example:
Note that if you try to remove a tag from a partition that is not available, that is, from a partition that is in use, you will get a result like this:
Not Found
On the other hand, if you try to remove a tag that is not assigned to the partition you’ve chosen, MAAS will simply return Success, followed by a JSON sequence describing the current state of the partition.
| @tsv' | column -t
For example:
| @tsv' | column -t
id tags
54 farquar swap opendisk
67 foobar farquar
97 foobar
To view tags for one partition, enter a command similar to this:
For example:
This command should produce output similar to this:
id tags
67 foobar farquar
