How to commission machines (deb/2.9/CLI)
How to commission a machine
To commission a machine that’s in the “Ready” state, via the CLI, use the following command:
Typical JSON output (long listing)
    "storage_test_status_name": "Pending",
    "bcaches": [],
    "cpu_count": 1,
    "interface_set": [
            "params": "",
            "numa_node": 0,
            "tags": [],
            "id": 10,
            "mac_address": "52:54:00:15:36:f2",
            "vendor": "Red Hat, Inc.",
            "children": [],
            "effective_mtu": 1500,
            "discovered": [],
            "links": [],
            "link_speed": 0,
            "link_connected": true,
            "system_id": "bhxws3",
            "enabled": true,
            "interface_speed": 0,
            "firmware_version": null,
            "name": "ens3",
            "sriov_max_vf": 0,
            "product": null,
            "vlan": {
                "vid": 0,
                "mtu": 1500,
                "dhcp_on": true,
                "external_dhcp": null,
                "relay_vlan": null,
                "fabric": "fabric-2",
                "primary_rack": "8dwnne",
                "name": "untagged",
                "id": 5003,
                "space": "undefined",
                "secondary_rack": null,
                "fabric_id": 2,
            "parents": [],
            "type": "physical",
            "resource_uri": "/MAAS/api/2.0/nodes/bhxws3/interfaces/10/"
    "numanode_set": [
            "index": 0,
            "memory": 985,
            "cores": [
                0
    "locked": false,
    "hardware_uuid": "F677A842-571C-4E65-ADC9-11E2CF92D363",
    "default_gateways": {
        "ipv4": {
            "gateway_ip": null,
            "link_id": null
        "ipv6": {
            "gateway_ip": null,
            "link_id": null
    "status_action": "",
    "status_message": "Commissioning",
    "memory_test_status": -1,
    "virtualblockdevice_set": [],
    "pool": {
        "name": "default",
        "id": 0,
    "current_testing_result_id": 9,
    "netboot": true,
    "description": "",
    "special_filesystems": [],
    "testing_status": 0,
    "memory": 1024,
    "current_commissioning_result_id": 8,
    "storage": 5368.70912,
    "commissioning_status": 0,
    "cpu_test_status": -1,
    "tag_names": [
        "virtual"
    "swap_size": null,
    "status_name": "Commissioning",
    "other_test_status": -1,
    "pod": null,
    "storage_test_status": 0,
    "blockdevice_set": [
            "id_path": "/dev/disk/by-id/ata-QEMU_HARDDISK_QM00001",
            "size": 5368709120,
            "block_size": 512,
            "tags": [
                "ssd"
            "serial": "QM00001",
            "uuid": null,
            "numa_node": 0,
            "available_size": 5368709120,
            "id": 3,
            "partition_table_type": null,
            "model": "QEMU HARDDISK",
            "storage_pool": null,
            "used_for": "Unused",
            "filesystem": null,
            "used_size": 0,
            "partitions": [],
            "name": "sda",
            "type": "physical",
            "resource_uri": "/MAAS/api/2.0/nodes/bhxws3/blockdevices/3/"
    "distro_series": "",
    "testing_status_name": "Pending",
    "ip_addresses": [],
    "address_ttl": null,
    "physicalblockdevice_set": [
            "firmware_version": "2.5+",
            "uuid": null,
            "numa_node": 0,
            "size": 5368709120,
            "tags": [
                "ssd"
            "id": 3,
            "filesystem": null,
            "used_size": 0,
            "partitions": [],
            "name": "sda",
            "block_size": 512,
            "type": "physical",
    "fqdn": "ace-swan.maas",
    "osystem": "",
    "domain": {
        "authoritative": true,
        "ttl": null,
        "resource_record_count": 0,
        "name": "maas",
        "id": 0,
        "is_default": true,
    "boot_interface": {
        "params": "",
        "numa_node": 0,
        "tags": [],
        "id": 10,
        "children": [],
        "discovered": [],
        "links": [],
        "link_speed": 0,
        "enabled": true,
        "name": "ens3",
        "sriov_max_vf": 0,
        "product": null,
        "vlan": {
            "vid": 0,
            "mtu": 1500,
            "dhcp_on": true,
            "relay_vlan": null,
            "name": "untagged",
            "id": 5003,
            "fabric_id": 2,
        "parents": [],
        "type": "physical",
    "hostname": "ace-swan",
    "network_test_status": -1,
    "min_hwe_kernel": "",
    "power_state": "off",
    "owner_data": {},
    "volume_groups": [],
    "power_type": "virsh",
    "node_type": 0,
    "owner": "admin",
    "cache_sets": [],
    "hwe_kernel": null,
    "zone": {
        "name": "default",
        "description": "",
        "id": 1,
    "disable_ipv4": false,
    "boot_disk": {
        "uuid": null,
        "numa_node": 0,
        "size": 5368709120,
        "tags": [
            "ssd"
        "id": 3,
        "filesystem": null,
        "used_size": 0,
        "partitions": [],
        "name": "sda",
        "block_size": 512,
        "type": "physical",
    "status": 1,
    "iscsiblockdevice_set": [],
    "raids": [],
    "node_type_name": "Machine",
    "hardware_info": {
        "system_vendor": "QEMU",
        "system_product": "Standard PC (i440FX + PIIX, 1996)",
        "system_family": "Unknown",
        "system_version": "pc-i440fx-focal",
        "system_sku": "Unknown",
        "system_serial": "Unknown",
        "cpu_model": "Intel Core Processor (Skylake, IBRS)",
        "mainboard_vendor": "Unknown",
        "mainboard_product": "Unknown",
        "mainboard_firmware_vendor": "SeaBIOS",
        "mainboard_firmware_date": "04/01/2014",
        "mainboard_firmware_version": "1.13.0-1ubuntu1",
        "chassis_vendor": "QEMU",
        "chassis_type": "Other",
        "chassis_serial": "Unknown",
        "chassis_version": "pc-i440fx-focal"
    "commissioning_status_name": "Pending",
    "bios_boot_method": "pxe",
    "interface_test_status": -1,
    "cpu_speed": 0,
    "resource_uri": "/MAAS/api/2.0/machines/bhxws3/"
If you need to find the machine’s $SYSTEM_ID, you can use a command like this one:
"ace-swan"
"bhxws3"
How to manage commissioning and testing scripts
This section explains:
How to upload hardware testing scripts
How to list all uploaded hardware testing scripts
How to update hardware testing scripts
"history": [
        "id": 40,
        "comment": "Updated version"
        "id": 34,
        "comment": null
How to revert hardware testing scripts
MAAS keeps a history of all uploaded script versions, allowing you to easily revert to a previous version, using the id of the desired version:
How to download a script
How to delete a script
How to view script results
How to filter script results
How to suppress failed results
"results": [
        "id": 21,
        "name": "smartctl-validate",
        "status": 5,
        "status_name": "Aborted",
        "exit_status": null,
        "runtime": "0:00:00",
        "endtime": 1554238601.765214,
        "parameters": {
            "storage": {
                "argument_format": "{path}",
                "type": "storage",
                "value": {
                    "id_path": "/dev/vda",
                    "model": "",
                    "name": "sda",
                    "physical_blockdevice_id": 1,
                    "serial": ""
        "script_id": 1,
        "script_revision_id": null,
        "suppressed": true
How to locate script files
How to locate log files
  1. /tmp/user_data.sh*/out/
  3. /var/log/cloud-init.log
    [--no-download] \
    [--no-send] \
    /tmp/user_data.sh.*
Where:
