How to commission machines (snap/3.0/UI)
2.9 3.0
DEB CLI ~ UI CLI ~ UI
SNAP CLI ~ UI CLI ~ UI
How to commission a machine
To commission a machine:
  1. Go to the “Machines” page.
  2. Select the machine(s) you want to commission.
  3. Choose “Commission” under the “Take action” drop-down menu:
These options include:
  • Allow SSH access and prevent machine powering off: Machines are normally powered off after commissioning. This option keeps the machine on and enables SSH so you can access the machine.
  • Retain network configuration: When enabled, preserves any custom network settings previously configured for the machine. See Networking for more information.
  • Retain storage configuration: When enabled, preserves any storage settings previously configured for the machine. See Storage for more details.
  • Update firmware: Runs scripts tagged with update_firmware.
  • Configure HBA: Runs scripts tagged with configure_hba.
  1. Click the Hardware tests field to reveal a drop-down list of tests to add and run during commissioning. See Hardware testing for more information on hardware testing scripts.
  2. Finalise the directive by hitting “Commission machine”.
How to manage commissioning and testing scripts
This section explains:
How to upload scripts
How to debug script failures
How to locate script files
How to locate log files
  1. /tmp/user_data.sh*/out/
  3. /var/log/cloud-init.log
    [--no-download] \
    [--no-send] \
    /tmp/user_data.sh.*
Where:
