How to commission a machine
To commission a machine:
Go to the “Machines” page.
Select the machine(s) you want to commission.
Choose “Commission” under the “Take action” drop-down menu:
These options include:
Allow SSH access and prevent machine powering off: Machines are normally powered off after commissioning. This option keeps the machine on and enables SSH so you can access the machine.
Retain network configuration: When enabled, preserves any custom network settings previously configured for the machine. See Networking for more information.
Retain storage configuration: When enabled, preserves any storage settings previously configured for the machine.
Update firmware: Runs scripts tagged with
update_firmware. -
Configure HBA: Runs scripts tagged with
configure_hba.
Click the Hardware tests field to reveal a drop-down list of tests to add and run during commissioning.
Finalise the directive by hitting “Commission machine”.
How to manage commissioning and testing scripts
This section explains:
- How to download built-in scripts
- How to upload scripts
- How to debug script failures
- How to locate script files
- How to locate log files
- How to run all scripts manually
/tmp/user_data.sh.*/scripts/commissioning/: Commissioning scripts -
/tmp/user_data.sh.*/scripts/testing/: Hardware testing scripts
/tmp/user_data.sh*/out//var/log/cloud-init-output.log/var/log/cloud-init.log
[--no-download] \
[--no-send] \
/tmp/user_data.sh.*
Where:
--no-download: Optional. Do not download the scripts from MAAS again. -
--no-send: Optional. Do not send the results to MAAS.
