Erasure types
The three types of erasure types are:
- Standard erase
- Secure erase
- Quick erase
Standard erase
Secure erase
Quick erase
Default configuration
Order of preference
- Use ‘secure erase’ if the disk supports it
- If it does not then use ‘quick erase’
