Six questions you may have:
- How does UEFI booting work?
- What kind of storage layouts are available?
- How do I set global storage layouts?
- How do I set per-machine storage layouts?
- What storage modifications can I make at the filesystem level?
- How can I erase a disk?
UEFI
Layouts
There are three layout types:
- Flat layout
- LVM layout
- bcache layout
Flat layout
| Name | Size | Type | Filesystem | Mount point |
| sda | - | disk | ||
| sda1 | 512 MB | part | FAT32 | /boot/efi |
| sda2 | rest of sda | part | ext4 | / |
boot_size: Size of the boot partition on the boot disk. Default is 0, meaning not to create the boot partition. The ‘/boot’ will be placed on the root filesystem. -
root_device: The block device on which to place the root partition. The default is the boot disk. -
root_size: Size of the root partition. Default is 100%, meaning the entire size of the root device.
LVM layout
| sda | - | disk | ||
| sda2 | rest of sda | part | lvm-pv(vgroot) | |
| lvroot | rest of sda | lvm | ext4 | / |
| vgroot | rest of sda | lvm |
root_size: Size of the root partition. Default is 100%, meaning the entire size of the root device. -
vg_name: Name of the created volume group. Default isvgroot. -
lv_name: Name of the created logical volume. Default islvroot. -
lv_size: Size of the created logical volume. Default is 100%, meaning the entire size of the volume group.
bcache layout
| sda | - | disk | ||
| sda2 | rest of sda | part | bc-backing | |
| sdb (ssd) | - | disk | ||
| sdb1 | 100% of sdb | part | bc-cache | |
| bcache0 | per sda2 | disk | ext4 | / |
root_device: The block device upon which to place the root partition. The default is the boot disk. -
cache_device: The block device to use as the cache device. Default is the smallest block device tagged ssd. -
cache_mode: The cache mode to which MAAS should set the created bcache device. The default iswritethrough. -
cache_size: The size of the partition on the cache device. Default is 100%, meaning the entire size of the cache device. -
cache_no_part: Whether or not to create a partition on the cache device. Default is false, meaning to create a partition using the givencache_size. If set to true, no partition will be created, and the raw cache device will be used as the cache.
VMFS6 layout
| Name | Size | Type | Use |
| sda | - | disk | |
| sda1 | 3 MB | part | EFI |
| sda2 | 4 GB | part | Basic Data |
| sda3 | Remaining | part | VMFS Datastore 1 |
| sda4 | - | skipped | |
| sda5 | 249 MB | part | Basic Data |
| sda6 | 249 MB | part | Basic Data |
| sda7 | 109 MB | part | VMware Diagnostic |
| sda8 | 285 MB | part | Basic Data |
| sda9 | 2.5 GB | part | VMware Diagnostic |
root_device: The block device upon which to place the root partition. Default is the boot disk. -
root_size: Size of the default VMFS Datastore. Default is 100%, meaning the remaining size of the root disk.
Blank layout
Setting layouts
Machine layout
Final storage modifications
