Creating and deleting VMs
If you have created a KVM host (a “pod”), you will want to create and delete virtual machines (VMs). You can use either the CLI or the UI for these operations; this article explains how.
Adding a VM from the Web UI
While on KVM host’s details view, select ‘Compose’ from the ‘Take action’ drop-down menu to compose a machine.
Click the ‘Compose machine’ button when you’re finished. MAAS will present the pod detail view. In a few moments, your new machine will be auto-commissioned. The ‘Machines’ page will reflect this as well.
MAAS will deduct the new machine’s resources from the pod’s resources:
Adding a VM from the CLI
To compose a basic pod VM:
maas $PROFILE pod compose $POD_ID
    "system_id": "73yxmc",
Set resources while adding a VM
maas $PROFILE pod compose $POD_ID $RESOURCES
Where RESOURCES is a space-separated list of constraints:
  • cores= requested cores
  • cpu_speed= requested minimum cpu speed in MHz
  • memory= requested memory in MB
  • architecture= See Architecture below
  • storage= See Storage below
  • interfaces= See Interfaces below
Setting the architecture while adding a VM
Then, for example:
maas $PROFILE pod compose $POD_ID \
Setting storage parameters while adding a VM
For example, to compose a machine with the following disks:
  • 32 GB disk from storage pool pool1
  • 64 GB disk from storage pool pool2
where we want the first disk to be a bootable root partition / and the second to be a home directory.
First, create the VM:
maas $PROFILE pod compose $POD_ID "storage=mylabel:32(pool1),mylabel:64(pool2)"
MAAS will create a pod VM with 2 disks, /dev/vda (32 GB) and /dev/vdb (64 GB). After MAAS enlists, commissions and acquires the machine, you can edit the disks before deploying to suit your needs. For example, we’ll set a boot, root and home partition.
We’ll start by deleting the / partition MAAS created because we want a separate /boot partition to demonstrate how yo.
maas admin partition delete $POD_ID $DISK1_ID $PARTITION_ID
To find $DISK1_ID and $PARTITION_ID, use maas admin machine read $POD_ID.
maas admin partitions create $POD_ID $DISK1_ID size=512000000 bootable=True
maas admin partitions create $POD_ID $DISK2_ID
To find $DISK2_ID, use maas admin machine read $POD_ID.
maas admin partition format $POD_ID $DISK1_ID $BOOT_PARTITION_ID fstype=ext2
maas admin partition format $POD_ID $DISK1_ID $ROOT_PARTITION_ID fstype=ext4
maas admin partition format $POD_ID $DISK2_ID $HOME_PARTITION_ID fstype=ext4
To find the partition IDs, use maas admin partitions read $POD_ID $DISK1_ID and maas admin partitions read $POD_ID $DISK2_ID
maas admin partition mount $SYSTEM_ID $DISK1_ID $BOOT_PARTITION_ID "mount_point=/boot"
Specifying interfaces while adding a VM
Using the interfaces constraint, you can compose virtual machines with interfaces, allowing the selection of pod NICs.
interfaces=eth0:space=maas,eth1:space=storage
Assuming you deploy the pod on a machine or controller with access to the maas and storage spaces, MAAS will create an eth0 interface bound to the maas space and an eth1 interface bound to the storage space.
MAAS automatically converts the ip constraint to a VLAN constraint (matching the VLAN which corresponds to the subnet can be found – e.g. 172.16.99.0/24.) and assigns the IP address to the newly-composed machine upon allocation.
See the Machines MAAS API documentation (op=allocate) for a list of all constraint keys.
Find pod IDs
Here’s a simple way to find a pod’s ID by name using jq:
maas $PROFILE pods read | jq '.[] | select (.name=="MyPod") | .name, .id'
Example output:
"MyPod"
1
Deleting a VM from the Web UI
Deleting a VM with the CLI
After you delete a machine, its resources will be available for other VMs.
