Creating and deleting VMs (CLI)
If you have created a VM host, you will want to create and delete virtual machines (VMs). You can use either the CLI or the UI for these operations; this article explains how.
Adding a VM from the Web UI
While on VM host’s details view, select ‘Compose’ from the ‘Take action’ drop-down menu to compose a machine.
Click the ‘Compose machine’ button when you’re finished. MAAS will present the VM host detail view. In a few moments, your new machine will be auto-commissioned. The ‘Machines’ page will reflect this as well.
MAAS will deduct the new machine’s resources from the VM host’s resources:
Adding a VM from the CLI
To compose a basic VM:
    "system_id": "73yxmc",
Set resources while adding a VM
Where $RESOURCES is a space-separated list of constraints:
  • cores= requested cores
  • cpu_speed= requested minimum cpu speed in MHz
  • memory= requested memory in MB
  • architecture= See Architecture below
  • storage= See Storage below
  • interfaces= See Interfaces below
Setting the architecture while adding a VM
Then, for example:
Setting storage parameters while adding a VM
For example, to compose a machine with the following disks:
  • 32 GB disk from storage pool pool1
  • 64 GB disk from storage pool pool2
where we want the first disk to be a bootable root partition / and the second to be a home directory.
First, create the VM:
MAAS will create a VM with 2 disks, /dev/vda (32 GB) and /dev/vdb (64 GB). After MAAS enlists, commissions and acquires the machine, you can edit the disks before deploying to suit your needs. For example, we’ll set a boot, root, and home partition.
We’ll start by deleting the / partition MAAS created because we want a separate /boot partition to demonstrate how yo.
maas admin partition mount $SYSTEM_ID $DISK1_ID $BOOT_PARTITION_ID     "mount_point=/boot"
Specifying interfaces while adding a VM
interfaces=eth0:space=maas,eth1:space=storage
MAAS automatically converts the ip constraint to a VLAN constraint (matching the VLAN which corresponds to the subnet can be found – e.g. 172.16.99.0/24.) and assigns the IP address to the newly-composed machine upon allocation.
See the Machines MAAS API documentation for a list of all constraint keys.
Find VM host IDs
maas $PROFILE vm-hosts read | jq '.[] | select (.name=="MyVMHost") | .name, .id'
Example output:
"MyVMHost"
1
Deleting a VM from the Web UI
Deleting a VM with the CLI
After you delete a machine, its resources will be available for other VMs.
