CLI composable hardware (snap/2.7/CLI)
This article provides a list of examples of VM host management tasks you can perform with the MAAS CLI.
Add a VM host
To add a VM host:
maas $PROFILE vm-hosts create type=$VM_HOST_TYPE power_address=$POWER_ADDRESS \
    [tags=$TAG1,$TAG2,...]
Both USERNAME and PASSWORD are optional for the virsh power type. ZONE and TAGS are optional for all VM hosts.
See the API reference for a listing of available power types.
For example, to create an RSD VM host:
And to create a KVM host:
Create a KVM host with overcommitted resources:
maas $PROFILE vm-hosts create type=virsh power_address=qemu+ssh://ubuntu@192.168.1.2/system \
        power_pass=example cpu_over_commit_ratio=0.3 memory_over_commit_ratio=4.6
Create a KVM host that uses a default storage pool:
        power_pass=example default_storage_pool=pool1
Find VM host IDs
maas $PROFILE vm-hosts read | jq '.[] | select (.name=="MyVMHost") | .name, .id'
jq is a command-line JSON processor. More details at https://stedolan.github.io/jq/
Example output:
"MyVMHost"
1
List resources of all VM hosts
        "id": 93,
        "capabilities": [
            "composable",
            "fixed_local_storage",
            "iscsi_storage"
        "name": "civil-hermit",
List resources of a VM host
Update VM host configuration
List VM host connection parameters
Example output:
    "power_pass": "admin",
    "power_user": "admin"
Compose VMs
Basic
To compose a basic VM:
    "system_id": "73yxmc",
Set resources
Where RESOURCES is a space-separated list from:
cores= requested cores
cpu_speed= requested minimum cpu speed in MHz
memory= requested memory in MB
architecture= See Architecture below
storage= See Storage below
interfaces= See Interfaces below
Architecture
Then, for example:
Storage
For example, to compose a machine with the following disks:
  • 32 GB disk from storage pool pool1
  • 64 GB disk from storage pool pool2
where you want to use the first as a bootable root partition / and the second to be used as a home directory.
First, create the VM:
MAAS will create a VM with 2 disks, /dev/vda (32 GB) and /dev/vdb (64 GB). After MAAS enlists, commissions and acquires the machine, you can edit the disks before deploying to suit your needs. For example, we’ll set a boot, root and home partition.
We’ll start by deleting the / partition MAAS created because we want a separate /boot partition to demonstrate how this might be done.
maas admin partition mount $SYSTEM_ID $DISK1_ID $BOOT_PARTITION_ID "mount_point=/boot"
Interfaces
"interfaces=eth0:space=maas;eth1:space=storage"
MAAS automatically converts the ip constraint to a VLAN constraint (for the VLAN where its subnet can be found – e.g. 172.16.99.0/24.) and assigns the IP address to the newly-composed machine upon allocation.
See the MAAS API documentation for a list of all constraint keys.
Compose and allocate a VM
In the absence of any nodes in the ‘New’ or ‘Ready’ state, if a VM host of sufficient resources is available, MAAS can automatically compose (add), commission, and acquire a VM. You can accomplish this with the allocate sub-command:
Note that all VM host resource parameters are available to the allocate command, so based on the example above, the following works:
maas $PROFILE machines allocate "storage=mylabel1:32(pool1),mylabel2:64(pool2)"
Once commissioned and acquired, the new machine will be ready to deploy.
The labels (i.e. mylabel1, mylabel2) in this case can be used to associate device IDs in the information MAAS dumps about the newly created VM. Try piping the output to: jq '.constraints_by_type'.
List machine parameters
MAAS VM parameters, including their resources, are listed just like any other machine:
Libvirt storage pools
Composing VMs with storage pool constraints
See Compose virtual machines.
Usage
Example:
    "used": {
        "cores": 50,
        "memory": 31744,
        "local_storage": 63110426112
    "name": "more-toad",
    "id": 5,
    "available": {
        "cores": 5,
        "memory": 4096,
        "local_storage": 153199988295
    "architectures": [],
    "cpu_over_commit_ratio": 1.0,
    "storage_pools": [
            "id": "pool_id-zvPk9C",
            "name": "name-m0M4ZR",
            "type": "lvm",
            "path": "/var/lib/name-m0M4ZR",
            "total": 47222731890,
            "used": 17226931712,
            "available": 29995800178,
            "default": true
            "id": "pool_id-qF87Ps",
            "name": "name-ZMaIta",
            "type": "lvm",
            "path": "/var/lib/name-ZMaIta",
            "total": 98566956569,
            "used": 15466229760,
            "available": 83100726809,
            "default": false
            "id": "pool_id-a6lyw5",
            "name": "name-RmDPfs",
            "type": "lvm",
            "path": "/var/lib/name-RmDPfs",
            "total": 70520725948,
            "used": 30417264640,
            "available": 40103461308,
            "default": false
    "total": {
        "cores": 55,
        "memory": 35840,
        "local_storage": 216310414407
    "tags": [],
    "type": "virsh",
    "pool": {
        "name": "default",
        "id": 0,
    "zone": {
        "name": "default",
        "description": "",
        "id": 1,
    "capabilities": [
        "dynamic_local_storage",
        "composable"
    "host": {
        "system_id": null,
        "__incomplete__": true
    "default_macvlan_mode": null,
    "resource_uri": "/MAAS/api/2.0/pods/5/"
Delete a VM
After you delete a machine, the machine’s resources will be available for other VMs.
Delete a VM host
maas $PROFILE vm-host delete $VM_HOST_ID
Deleting a VM host will automatically delete all machines belonging to that VM host.
