This page has been deprecated in favor of newer terminology and technology. Please see the updated page.
After installing MAAS, the ‘KVM’ page is typically empty:
2.5+
Once MAAS has enlisted, commissioned, and acquired a newly-added machine, you can deploy it as a KVM host:
CLI
Once MAAS has enlisted, commissioned, and acquired a machine, you can deploy it as a KVM host:
maas $PROFILE machine deploy <system_id> install_kvm=True
Manual/Pre-2.5
Setting up a manual KVM host in 2.5 or on an older version of MAAS requires more steps.
Set up a `maas` libvirt network
Libvirt by default creates a virtual bridge, virbr0, through which VMs communicate with each other and the Internet. DHCP, supplied by libvirt, automatically assigns an IP address to each VM. However, to enable network booting in MAAS, you’ll need to provide DHCP in MAAS and either:
- Disable DHCP on libvirt’s
defaultnetwork, or - Create a new libvirt network
maaswith DHCP disabled.
cat << EOF > maas.xml
<network>
<name>maas</name>
<forward mode='nat'>
<nat>
</nat>
</forward>
<dns enable="no" />
<domain name='testnet'/>
</ip>
</network>
EOF
virsh net-define maas.xml
Set up SSH
For MAAS to successfully communicate with libvirt on your KVM host machine, this example command must succeed from every rack controller as user maas:
virsh -c qemu+ssh://$USER@$KVM_HOST_IP/system list --all
Here, $USER is a user on your KVM host who is a member of the libvirtd Unix group on the KVM host, and $KVM_HOST_IP is the IP of your KVM host.
MAAS package installs
The maas user on your rack controllers will issue all virsh commands. Therefore, you’ll need to set up SSH public keys on every rack controller for user maas.
If you installed MAAS via packages, first create SSH keys on all rack controllers:
sudo chsh -s /bin/bash maas
sudo su - maas
ssh-keygen -t rsa -N ''
Next, add the contents of ~maas/.ssh/id_rsa.pub to the KVM host user’s ~$USER/.ssh/authorized_keys. To accomplish this, log into your KVM host node, via SSH, from a host for which MAAS has a matching public SSH key.
MAAS snap installs
sudo ssh-keygen -f id_rsa
Finally, you’ll need to add id_rsa.pub to the authorized_keys file in /home/<kvm-host-user-homedir-name>/.ssh/, where <kvm-host-user-homedir-name> is the name of your KVM host user.
Insufficient permissions for $USER may cause the virsh command to fail with an error such as failed to connect to the hypervisor. Check the $USER group membership to make sure $USER is a member of the libvirtd group.
Add
Now, add a KVM host by using the ‘Add pod’ button. Choose ‘Virsh (Virtual systems)’ from the ‘Pod type’ drop-down menu.
Here, ‘Virsh address’ typically looks like the following:
qemu+ssh://<kvm host IP>/system
MAAS will automatically discover and store the resources your KVM host contains. Any existing machines will also appear on the ‘Machines’ page, and MAAS will automatically attempt to commission them.
Add with CLI
Create a KVM host:
maas $PROFILE pods create type=virsh power_address=qemu+ssh://ubuntu@192.168.1.2/system
Create a KVM host with overcommitted resources:
maas $PROFILE pods create type=virsh power_address=qemu+ssh://ubuntu@192.168.1.2/system \
power_pass=example cpu_over_commit_ratio=0.3 memory_over_commit_ratio=4.6
Create a KVM host that uses a default storage pool:
power_pass=example default_storage_pool=pool1
Configuration
KVM hosts have several configuration options. Modify these by selecting the ‘Configuration’ tab and clicking ‘Edit’. Options include a KVM host’s location, password, network zone, and default resource pool.
Overcommit resources
Overcommitted resources are those allocated beyond what’s available in the physical resource. Using sliders on the configuration page, you can limit whether MAAS will attempt to overcommit CPU and memory. The input fields to the right of the sliders accept floating-point values from 0 to 10, with a default value of 1.
The following shows theoretical examples of these ratios and how they affect physical resource allocation:
8 physical CPU cores * 1 multiplier = 8 virtual CPU cores8 physical CPU cores * 0.5 multiplier = 4 virtual CPU cores32 physical CPU cores * 10.0 multiplier = 320 virtual CPU cores128GB physical memory * 5.5 multiplier = 704G virtual Memory
Overcommitting resources allows a user to compose many MAAS-managed machines without worrying about the physical limitations of the host. For example, on a physical host with four cores and 12 GB of memory, you could compose four virsh machines, each using two cores and 4 GB of memory. This arrangement overcommits the available physical resources. Provided you never run all four simultaneously, you’d have all the benefits of MAAS-managed VMs without over-taxing your host.
