Subnet management (deb/3.0/UI)
2.9 3.0
DEB CLI ~ UI CLI ~ UI
SNAP CLI ~ UI CLI ~ UI
Four questions you may have:
  1. What are managed subnets?
  2. What are unmanaged subnets?
  3. What is IP address tracking?
  4. How do I control subnet management
Managed subnets
Unmanaged subnets
Controlling subnet management
To disable (or re-enable) subnet management navigate to the ‘Subnets’ page and select the subnet. Press the ‘Edit’ button to allow changes. The ‘Managed allocation’ field will become a slide switch. Click the label (or the switch icon itself) to toggle between enabled (dark blue) and disabled (grey) and click ‘Save summary’.
IP address tracking
