Subnet management (deb/2.7/CLI)
Seven questions you may have:
  1. What are managed subnets?
  2. What are unmanaged subnets?
  3. What is IP address tracking?
  4. How do I control subnet management
  5. How do I determine a fabric ID to use in other CLI subnet calls?
  6. How do I set a default gateway with the CLI?
  7. How do i set the DNS server with the CLI?
Managed subnets
Unmanaged subnets
Controlling subnet management
For example, to disable:
You can use the subnet’s ID in place of the CIDR address.
Determine fabric ID
This may come in handy when you need a fabric ID for other CLI calls.
Set a default gateway
Set a DNS server
maas $PROFILE subnet update $SUBNET_CIDR dns_servers=$MY_NAMESERVER
IP address tracking
