This article delves into these issues, offering guidance on setting up and managing your DHCP configuration.
Twelve questions you may have:
- What are reserved IP ranges?
- What is post-commission configuration
- How and why should I enable MAAS-managed DHCP?
- How do I resolve IP conflicts?
- How can I extend a reserved dynamic IP range?
- How and why should I configure external DHCP?
- How and why should I use a DHCP relay?
- How and why should I customise MAAS with DHCP snippets?
- How do I create an A or AAAA record in DNS?
- How do I create an alias (CNAME) record in DNS?
- How do I create a Mail Exchange pointer record in DNS?
- How do I set a DNS forwarder?
Enabling DHCP
- Under the ‘Take action’ button select ‘Provide DHCP’. A new window will appear.
- Select the primary rack controller. For DHCP HA, select both the primary and the secondary.
- Create a reserved, dynamic IP range. Fill in the fields ‘Dynamic range start IP’ and ‘Dynamic range end IP’.
- Apply your changes with the ‘Provide DHCP’ button.
Resolving IP conflicts
In some cases, MAAS manages a subnet that is not empty, which could result in MAAS assigning a duplicate IP address. MAAS is capable of detecting IPs in use on a subnet. Be aware that there are two caveats:
- If a previously-assigned NIC is in a quiescent state or turned off, MAAS may not detect it before duplicating an IP address.
2/ At least one rack controller must have access to the IP-assigned machine in order for this feature to work.
Extending a reserved dynamic IP range
External DHCP and a reserved IP range
DHCP relay
Ensure the target VLAN has DHCP enabled.
Set up the external relay. This relay is set up independently from MAAS. See DHCP relay for software suggestions.
Configure MAAS-managed DHCP. Navigate to the source VLAN page and select the ‘Relay DHCP’ action. Fill in the fields in the resulting form. The crucial setting is the target VLAN (‘Relay VLAN’). Press the ‘Relay DHCP’ button to finish.
DHCP Snippets
Setting DNS parameters
It is possible to set DNS parameters using the MAAS CLI, using the following instructions.
Set a DNS forwarder
To set a DNS forwarder:
