Hello all,
I have a Baremetal With KVM and LXD Running, I have a MAAS LXC Container and added the BareMetal KVM as POD to it.
When I spawn a KVM using MAAS, I must manually adjust the network connection on the KVM in order for it to boot to the MAAS Network.
- I connect to the VM using the UI
- I go to the NIC
- change network source to “specify shared device name”
- type in the maas bridge
- apply
- force reset
- then it pxe boots
The question is, on the KVM Service Settings, how do i setup the default network to be the MAAS one?
I’ve gone through these 3 blogs and haven’t figured this out yet.
https://www.buihanotes.com/2019/10/use-maas-to-manage-local-computing.html
