This article will show you:
- How to create and assign controller tags
- How to remove and delete controller tags
- How to view controller tags
- Click on the “Controllers” tab to open the controllers page:
- Click on the hyperlinked name of the controller to which you want to assign tags. You will see a screen with several cards, like this one:
Find the “Tags” card and click on “Edit.” You will be brought to that controller’s “Configuration” tab.
Click on the “Edit” button for “Controller configuration.”
- Follow the general procedure to assign a tag to the controller.
- Follow the general procedure to remove a tag from the controller.
- Click on the hyperlinked name of the controller of interest… You will see a screen with several cards, like this one:
- Find the “Tags” card; this card will list all the tags assigned to this controller.
