How to use controller tags (snap/2.9/UI)
This article will show you:
How to create and assign controller tags
  1. Click on the “Controllers” tab to open the controllers page:
  1. Click on the hyperlinked name of the controller to which you want to assign tags. You will see a screen with several cards, like this one:
  1. Find the “Tags” card and click on “Edit.” You will be brought to that controller’s “Configuration” tab.
  2. Click on the “Edit” button for “Controller configuration.”
  1. Follow the general procedure to assign a tag to the controller.
How to remove and delete controller tags
  1. Follow the general procedure to remove a tag from the controller.
How to view controller tags
  1. Click on the hyperlinked name of the controller of interest… You will see a screen with several cards, like this one:
  1. Find the “Tags” card; this card will list all the tags assigned to this controller.
