How to use controller tags (snap/3.0/CLI)
This article will show you:
How to discover the ID of your region controller(s)
| jq -r '(["name","id"]
| @tsv' | column -t
For example:
| @tsv' | column -t
name                         id
bill-Lenovo-Yoga-C740-15IML  86xya8
How to assign tags to a region controller
For example:
    "added": 1,
    "removed": 0
How to remove tags from a region controller
For example:
    "added": 0,
    "removed": 1
How to list tags for all region controllers
For example:
hostname                     sysid   tags
bill-Lenovo-Yoga-C740-15IML  86xya8  virtual  lxd-vm-host
How to view tags for one region controller
For example:
| @tsv' | column -t
hostname                     sysid   tags
How to discover the ID of your rack controller(s)
| @tsv' | column -t
For example:
| @tsv' | column -t
name                         id
How to assign tags to a rack controller
For example:
    "added": 1,
    "removed": 0
How to remove tags from a rack controller
For example:
    "added": 0,
    "removed": 1
How to list tags for all rack controllers
For example:
hostname                     sysid   tags
How to view tags for one rack controller
For example:
```nohighlight
| @tsv' | column -t
hostname                     sysid   tags
