For machines deploying Ubuntu, the username is
ubuntu, and the login would beubuntu@$MACHINE_IP. -
For machines deploying CentOS 7, the username is
centos, and the login would becentos@$MACHINE_IP. -
For machines deploying CentOS 8, the username is
cloud-user, and the login would becloud-user@$MACHINE_IP.
Note there is a trick for determining the correct machine login, which works on many different versions of Linux.  If you attempt to ssh root@$MACHINE_IP, this will fail, but often tells you which user you should be using.
Nodes hang on “Commissioning”
Possible Cause: Timing issues
Node deployment fails
to apt keyring
line 540, in add_apt_key_raw
    cmd=args)
Exit code: 2
Reason: -
Stdout: ''
Nodes fail to PXE boot
Possible Cause: DHCP conflict
Can’t log in to node
Can’t find MAAS web UI
- Check that the webserver is running - By default the web interface uses Apache, which runs under the service name apache2. To check it, on the MAAS server box you can run
sudo /etc/init.d/apache2 status. - Check that the hostname is correct - It may seem obvious, but check that the hostname is being resolved properly. Try running a browser (even a text mode one like
elinks) on the same box as the MAAS server and navigating to the page. If that doesn’t work, tryhttp://127.0.0.1:5240/MAAS/, which will always point at the local server. - If you are still getting “404 - Page not found” errors, check that the MAAS web interface has been installed in the right place. There should be a file present called
/usr/share/maas/maas/urls.py.
Backdoor image login
Extract the cloud image
For example:
mkdir xenial
Generate password hash
Rebuild SquashFS image
[=======]  2516/26975   9%
Use the custom image
mv squashfs squashfs_original
chown maas:maas squashfs
