For machines deploying Ubuntu, the username is
ubuntu
, and the login would beubuntu@$MACHINE_IP
For machines deploying CentOS 7, the username is
centos
, and the login would becentos@$MACHINE_IP
For machines deploying CentOS 8, the username is
cloud-user
, and the login would becloud-user@$MACHINE_IP
Note there is a trick for determining the correct machine login, which works on many different versions of Linux. If you attempt to ssh root@$MACHINE_IP
, this will fail, but often tells you which user you should be using.
Nodes hang on “Commissioning”
Possible Cause: Timing issues
Node deployment fails
As an example, an improperly configured PPA was added to MAAS which caused nodes to fail deployment. After entering Rescue mode and connecting via SSH, the following was discovered in file /var/log/cloud-init-output.log
to apt keyring
line 540, in add_apt_key_raw
cmd=args)
Exit code: 2
Reason: -
Stdout: ''
Nodes fail to PXE boot
Possible Cause: DHCP conflict
Can’t log in to node
As long as you have sudo privileges the maas
command can be used to change the password for a MAAS administrator on the MAAS region controller:
Can’t find MAAS web UI
By default, the web UI is located at http://<hostname>:5240/MAAS/
. If you can’t access it, there are a few things to try:
- Check that the webserver is running - By default the web interface uses Apache, which runs under the service name apache2. To check it, on the MAAS server box you can run
sudo /etc/init.d/apache2 status
. - Check that the hostname is correct - It may seem obvious, but check that the hostname is being resolved properly. Try running a browser (even a text mode one like
elinks
) on the same box as the MAAS server and navigating to the page. If that doesn’t work, tryhttp://127.0.0.1:5240/MAAS/
, which will always point at the local server. - If you are still getting “404 - Page not found” errors, check that the MAAS web interface has been installed in the right place. There should be a file present called
/usr/share/maas/maas/urls.py
Backdoor image login
Extract the cloud image
For example:
mkdir xenial
sudo
is required when extracting the image filesystem and when making changes to the files extracted from the image filesystem.
Generate password hash
Open the xenial/etc/shadow
file extracted from the image with a text editor and insert the password hash into the root user line of etc/shadow
, between the first and second colons:
Rebuild SquashFS image
Recent versions of MAAS use SquashFS to hold the ephemeral image filesystem. The final step is to use the following command to create a SquashFS file called xenial-customized.squashfs
that contains the modified shadow file:
[=======] 2516/26975 9%
Use the custom image
Images are synchronised by the region controller and stored on the rack controller in /var/lib/maas/boot-resources/
, with the current directory linking to the latest synchronised images.
mv squashfs squashfs_original
chown maas:maas squashfs
