This page explains how to work with tags.
Naming tags
- Tag names can include any combination of alphabetic letters (a-zA-Z), numbers (0-9), dashes (-) and underscores (_).
- Tag names can be a maximum of 256 characters in length.
- Tag names cannot include spaces.
Download H/W info (UI)
To download hardware configuration information in XML format, select Machines > machine (allocated or deployed) > Logs > Installation output > Download > Machine output (XML)
You can learn more about the returned information^ if desired. Note that:
- Size and capacity can have various meanings depending on the device
- The size of a node is always equal to its capacity
- Serial refers to the device’s serial number, but is used to report the MAC address for network devices, GUID for disk partition.
You can also find device classes from the same sources.
Adding tags (3.2++/UI)
To create and assign a tag to specific machines, select Machines > machine > Take action > Tag. In the pop-up tag dialogue, enter your proposed tag name in Search existing or add new tags, then select Create tag {tag-name}. Fill in the form:
Optionally enter a Comment.
Optionally enter Kernel options.
Select Create and add to tag changes > Save. You can confirm your changes by hovering over the Tags list in the Machines screen.
Adding tags (3.1–/UI)
The process for creating and assigning tags in the UI is generally the same for all tag types: Enter the name of the tag in the *Tags box and press the return key. Select the appropriate completion button to register your changes. The tag you just entered will now be added to the tag auto complete list, in alphabetical order, for re-use with other machines.
Adding tags (CLI)
"name": "new_tag",
"definition": ",
"kernel_opts": ",
Kernel option tags
This feature is only available via the MAAS CLI.
For example:
"name": "nomodeset_tag",
"definition": ",
| @tsv' | column -t
tag_name tag_comment kernel_options
virtual
new_tag a-new-tag-for-test-purposes
pod-console-logging console=tty1 console=ttyS0
nomodeset_tag nomodeset_kernel_option nomodeset vga
Removing tags (3.2++/UI)
You have two choices when it comes to eliminating tags from machines in your MAAS instance: you can delete them from all machines, or simply remove them from specific machines.
Deleting tags from all machines at once
To delete tags from all machines, select Machines > Tags > trash can icon > Delete. The tag will be unassigned from all machines and deleted. There is no undo.
Removing a tag from specific machines
To remove a tag only from specific machines, select Machines > machine(s) by checkbox > Take action > Tag. For each tag you wish to unassign, select Remove. When done, select Save to finalise your changes.
Removing tags (3.1–/UI)
With the MAAS UI, you remove tags, rather than explicitly deleting them. Tags are “deleted” when you have removed them from all machines:
Find the Tags box.
Click the X next to the tag you wish to remove.
When you’re done, select the appropriate completion button to register your changes.
Removing tags (CLI)
maas admin tag delete zorko
Unassign tags (UI)
To unassign tags from machines:
Select Machines.
Select the checkbox(es) next to the machine(s) you wish to untag.
Select Take action > Tag. A table of tags appears at the top of the screen.
For each tag you wish to unassign, select Remove. The text will change to Discard with an X to the right.
If you want to undo a choice before saving, click the X to right of Discard to undo the proposed change.
When you’re satisfied with your new tag configuration, select Save to finalise and register your choice(s).
Automatic tags cannot be unassigned manually. You can either update or delete automatic tags.
You can also unassign tags individually by going to Machines >> {machine-name} >> Configuration >> Tags >> Edit. The Tags table functions exactly the same as what’s described above.
List tagged nodes
To see how many nodes (Machines, controllers, devices) are tagged, search for GRUB_CMDLINE_LINUX_DEFAULT in the “Installation output” tab of the machine details page. That log should stay around for the lifetime of the deployment of the machine. The log gets overwritten when you redeploy the machine. For example:
GRUB_CMDLINE_LINUX_DEFAULT="sysrq_always_enabled dyndbg='file drivers/usb/* +p' console=tty1 console=ttyS0"
Update tags
For example:
"name": "new_tag",
"definition": ",
"kernel_opts": ",
List all tags
For example:
virtual
Rebuild a tag
"rebuilding": "virtual"
Automatic tags
MAAS 3.2 and above provide greatly expanded tagging capability (through the UI only). You can auto-apply tags to machines that match a custom XPath expression. Setting up an automatic tag lets you recognise special hardware characteristics and settings, e.g., the gpu passthrough.
Creating automatic tags (3.4)
To create automatic tags, select Organisation > Tags > Create new tag and fill in the form:
Enter the Tag name.
Enter an XPath-based Definition. A tag is considered automatic when the definition field is filled with an XPath expression. The current version of our UI will only validate if your XPath expression is valid or not, but it will not show you which machines it will apply to before you create the tag.
When done, select Save to register your changes. Once an automatic tag is created the screen will initially show that 0 machines are tagged. That is because MAAS is running a background task to auto-apply the tag to matching machines. It can take some time to see that the number of machines tagged is populating.
Pro tip: Kernel options will be applied at boot time. So by default kernel options will not be applied to any machines until they are deployed. If machines are deployed before they are tagged, the kernel option will be applied when these machines are redeployed.
Change tag definitions
To change tag definitions:
Select Organisation > Tags.
Select the pencil icon on the right end of the tag’s row.
Edit the Definition.
Select Save to register your changes.
Keep in mind that when a new definition is updated, MAAS will re-tag all the machines that match with the new definition. This can take some time, since it is a background process.
Creating automatic tags (3.3/3.2)
To create automatic tags, select Machines > Tags > Create new tag and fill in the form:
Enter the Tag name.
Select Save to register your changes. Once an automatic tag is created the screen will initially show that 0 machines are tagged. That is because MAAS is running a background task to auto-apply the tag to matching machines. It can take some time to see that the number of machines tagged is populating.
Kernel options will be applied at boot time. So, by default, kernel options will not be applied to any machines until they are deployed. If machines are deployed before they are tagged, the kernel option will be applied when these machines are redeployed.
Update tag definitions (UI)
To update tag definitions:
Select Machines > Tags.
Update tag kernel options
This feature is only available via the MAAS UI.
To update the kernel options on a tag:
Edit the Kernel options.
Kernel options can exist for both manual and automatic tags. However, they will be applied during boot time (commissioning and deploying).
If the tagged machines are deployed, the updated kernel option won’t apply until the machines are redeployed. We suggest that you release those machines prior to the update, then redeploy those machines when the kernel options of the tag are updated.
