Tags for different objects have similar purposes, but they aren’t necessarily administered in the same way – so we’ve included detailed articles for each tag type. That said, many of the common operations regarding tags are performed in the same way. This article will look at tag management steps that are the same (or very similar) across all types of MAAS tags.
How to name tags
- Tag names can include any combination of alphabetic letters (a-zA-Z), numbers (0-9), dashes (-) and underscores (_).
- Tag names can be a maximum of 256 characters in length.
- Tag names cannot include spaces.
How to create and assign tags
- Place the cursor in the “Tags” box, wherever it is located on the screen, and type the name of the new tag:
- Hit the return key to add the new tag:
- When you’re done, click on the appropriate completion button to complete the operation.
How to delete and remove tags
To remove (unassign) a tag:
- Find the “Tags” box, wherever it is located on the screen:
Click the “X” next to the tag you wish to remove.
