How to manage tags (snap/2.9/CLI)
Tags for different objects have similar purposes, but they aren’t necessarily administered in the same way – so we’ve included detailed articles for each tag type. That said, many of the common operations regarding tags are performed in the same way. This article will look at tag management steps that are the same (or very similar) across all types of MAAS tags.
How to name tags
How to create a tag
    "name": "new_tag",
    "definition": "",
    "kernel_opts": "",
How to create tags with built-in kernel options
For example:
    "name": "nomodeset_tag",
    "definition": "",
| @tsv' | column -t
virtual
How to delete a tag
maas admin tag delete zorko
How to update a tag
For example:
    "name": "new_tag",
    "definition": "",
    "kernel_opts": "",
How to list all tags available on this MAAS
For example:
virtual
How to rebuild a tag
    "rebuilding": "virtual"
