How to manage tags
Tags for different objects have similar purposes, but they aren’t necessarily administered in the same way – so we’ve included detailed articles for each tag type. That said, many of the common operations regarding tags are performed in the same way. This article will look at tag management steps that are the same (or very similar) across all types of MAAS tags.
How to name tags
How to create and assign tags
  1. Place the cursor in the “Tags” box, wherever it is located on the screen, and type the name of the new tag:
  1. Hit the return key to add the new tag:
  1. When you’re done, click on the appropriate completion button to complete the operation.
How to delete and remove tags
To remove (unassign) a tag:
  1. Find the “Tags” box, wherever it is located on the screen:
  1. Click the “X” next to the tag you wish to remove.
  2. When you’re done, click on the appropriate completion button to complete the operation.
How to create a tag
    "name": "new_tag",
    "definition": "",
    "kernel_opts": "",
How to create tags with built-in kernel options
For example:
    "name": "nomodeset_tag",
    "definition": "",
| @tsv' | column -t
virtual
How to delete a tag
maas admin tag delete zorko
How to update a tag
For example:
    "name": "new_tag",
    "definition": "",
    "kernel_opts": "",
How to list all tags available on this MAAS
For example:
virtual
How to rebuild a tag
    "rebuilding": "virtual"
