How to commission a machine
To commission a machine that’s in the “Ready” state, via the CLI, use the following command:
Typical JSON output (long listing)
"storage_test_status_name": "Pending",
"bcaches": [],
"cpu_count": 1,
"interface_set": [
"params": "",
"numa_node": 0,
"tags": [],
"id": 10,
"mac_address": "52:54:00:15:36:f2",
"vendor": "Red Hat, Inc.",
"children": [],
"effective_mtu": 1500,
"discovered": [],
"links": [],
"link_speed": 0,
"link_connected": true,
"system_id": "bhxws3",
"enabled": true,
"interface_speed": 0,
"firmware_version": null,
"name": "ens3",
"sriov_max_vf": 0,
"product": null,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"external_dhcp": null,
"relay_vlan": null,
"fabric": "fabric-2",
"primary_rack": "8dwnne",
"name": "untagged",
"id": 5003,
"space": "undefined",
"secondary_rack": null,
"fabric_id": 2,
"parents": [],
"type": "physical",
"resource_uri": "/MAAS/api/2.0/nodes/bhxws3/interfaces/10/"
"numanode_set": [
"index": 0,
"memory": 985,
"cores": [
0
"locked": false,
"hardware_uuid": "F677A842-571C-4E65-ADC9-11E2CF92D363",
"default_gateways": {
"ipv4": {
"gateway_ip": null,
"link_id": null
"ipv6": {
"gateway_ip": null,
"link_id": null
"status_action": "",
"status_message": "Commissioning",
"memory_test_status": -1,
"virtualblockdevice_set": [],
"pool": {
"name": "default",
"id": 0,
"current_testing_result_id": 9,
"netboot": true,
"description": "",
"special_filesystems": [],
"testing_status": 0,
"memory": 1024,
"current_commissioning_result_id": 8,
"storage": 5368.70912,
"commissioning_status": 0,
"cpu_test_status": -1,
"tag_names": [
"virtual"
"swap_size": null,
"status_name": "Commissioning",
"other_test_status": -1,
"pod": null,
"storage_test_status": 0,
"blockdevice_set": [
"id_path": "/dev/disk/by-id/ata-QEMU_HARDDISK_QM00001",
"size": 5368709120,
"block_size": 512,
"tags": [
"ssd"
"serial": "QM00001",
"uuid": null,
"numa_node": 0,
"available_size": 5368709120,
"id": 3,
"partition_table_type": null,
"model": "QEMU HARDDISK",
"storage_pool": null,
"used_for": "Unused",
"filesystem": null,
"used_size": 0,
"partitions": [],
"name": "sda",
"type": "physical",
"resource_uri": "/MAAS/api/2.0/nodes/bhxws3/blockdevices/3/"
"distro_series": "",
"testing_status_name": "Pending",
"ip_addresses": [],
"address_ttl": null,
"physicalblockdevice_set": [
"firmware_version": "2.5+",
"uuid": null,
"numa_node": 0,
"size": 5368709120,
"tags": [
"ssd"
"id": 3,
"filesystem": null,
"used_size": 0,
"partitions": [],
"name": "sda",
"block_size": 512,
"type": "physical",
"fqdn": "ace-swan.maas",
"osystem": "",
"domain": {
"authoritative": true,
"ttl": null,
"resource_record_count": 0,
"name": "maas",
"id": 0,
"is_default": true,
"boot_interface": {
"params": "",
"numa_node": 0,
"tags": [],
"id": 10,
"children": [],
"discovered": [],
"links": [],
"link_speed": 0,
"enabled": true,
"name": "ens3",
"sriov_max_vf": 0,
"product": null,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"relay_vlan": null,
"name": "untagged",
"id": 5003,
"fabric_id": 2,
"parents": [],
"type": "physical",
"hostname": "ace-swan",
"network_test_status": -1,
"min_hwe_kernel": "",
"power_state": "off",
"owner_data": {},
"volume_groups": [],
"power_type": "virsh",
"node_type": 0,
"owner": "admin",
"cache_sets": [],
"hwe_kernel": null,
"zone": {
"name": "default",
"description": "",
"id": 1,
"disable_ipv4": false,
"boot_disk": {
"uuid": null,
"numa_node": 0,
"size": 5368709120,
"tags": [
"ssd"
"id": 3,
"filesystem": null,
"used_size": 0,
"partitions": [],
"name": "sda",
"block_size": 512,
"type": "physical",
"status": 1,
"iscsiblockdevice_set": [],
"raids": [],
"node_type_name": "Machine",
"hardware_info": {
"system_vendor": "QEMU",
"system_product": "Standard PC (i440FX + PIIX, 1996)",
"system_family": "Unknown",
"system_version": "pc-i440fx-focal",
"system_sku": "Unknown",
"system_serial": "Unknown",
"cpu_model": "Intel Core Processor (Skylake, IBRS)",
"mainboard_vendor": "Unknown",
"mainboard_product": "Unknown",
"mainboard_firmware_vendor": "SeaBIOS",
"mainboard_firmware_date": "04/01/2014",
"mainboard_firmware_version": "1.13.0-1ubuntu1",
"chassis_vendor": "QEMU",
"chassis_type": "Other",
"chassis_serial": "Unknown",
"chassis_version": "pc-i440fx-focal"
"commissioning_status_name": "Pending",
"bios_boot_method": "pxe",
"interface_test_status": -1,
"cpu_speed": 0,
"resource_uri": "/MAAS/api/2.0/machines/bhxws3/"
If you need to find the machine’s $SYSTEM_ID, you can use a command like this one:
"ace-swan"
"bhxws3"
How to manage commissioning and testing scripts
This section explains:
- How to download built-in scripts
- How to upload hardware testing scripts
- How to list all uploaded hardware testing scripts
- How to update hardware testing scripts
- How to revert hardware testing scripts
- How to download a script
- How to view script results
- How to filter script results
- How to suppress failed results
- How to locate script files
- How to locate log files
- How to run all scripts manually
"history": [
"id": 40,
"comment": "Updated version"
"id": 34,
"comment": null
MAAS keeps a history of all uploaded script versions, allowing you to easily revert to a previous version, using the id of the desired version:
How to delete a script
"results": [
"id": 21,
"name": "smartctl-validate",
"status": 5,
"status_name": "Aborted",
"exit_status": null,
"runtime": "0:00:00",
"endtime": 1554238601.765214,
"parameters": {
"storage": {
"argument_format": "{path}",
"type": "storage",
"value": {
"id_path": "/dev/vda",
"model": "",
"name": "sda",
"physical_blockdevice_id": 1,
"serial": ""
"script_id": 1,
"script_revision_id": null,
"suppressed": true
/tmp/user_data.sh.*/scripts/commissioning/: Commissioning scripts -
/tmp/user_data.sh.*/scripts/testing/: Hardware testing scripts
/tmp/user_data.sh*/out//var/log/cloud-init-output.log/var/log/cloud-init.log
[--no-download] \
[--no-send] \
/tmp/user_data.sh.*
Where:
--no-download: Optional. Do not download the scripts from MAAS again. -
--no-send: Optional. Do not send the results to MAAS.
